Question about Ovens
Can you tell me how to turn on a tecno fan forced oven? It has been turned off by power interuption and now the clock is flashing with 0.00 and 1 and Auto? Please help.... thanks
  • 24 Answers
Most digital clocks have several buttons underneath them they are usually set by pressing 2 of the buttons at the same time and then the up down button for the time sometimes the up down setting is done by rotating a knob you will know when you have chosen the correct buttons the numbers will stop flashing failing that relist your problem with a model name and number if you can find one
Posted on May 30, 2011
My Chef Select fan forced oven has no heat. I have replaced the fan motor and the element, but still no heat. What else could be wrong with it?
Check that it is not been set on automatic. Try turning the timer /clock control through 24hrs and it may go click, fixed
Feb 21, 2013 | Ovens
How do I turn my omega oven europa 60-1 on? I turn the knobs, the electric clock is flashing but nothing comes on?
Can anyone tell me how to turn off my omega europa 60-1 oven. I have put both temp and fan to off but oven fan still going Help please as cannot find isolating switch thanks
Oct 08, 2011 | General Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
Bulb blown and now fan is not working
When you changed the bulb did you turn the power off at the mains if so then you need to reset the clock on the front panel the fan will not work but all other functions will look in book it will tell you clock reset.Hope I helped.
Good Luck.
May 07, 2010 | Bosch HBN 730520B / 730560B Electric...
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
The oven will not operate after I switched the mains power off. The clock is flashing 0. Any help appreciated !
I dont know your model but it seems like the clock needs resetting if you have a manual it will tell you in the book.if not just keep pushing buttons. normally holding the 2 on rhs then pressing other buttons can do it keep fan oven switched on as you try to reset
Hope this helps.
Good Luck.
Apr 11, 2010 | Ovens
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
How do i turn on the oven?
First set the clock if you cant do that just press buttons till the numbers stop flashing the turn the knob with pictures to one that looks like a fan in a box that should be fan forced option the select the tempreture with the other knob
hope it helps
Aug 17, 2009 | Fisher and Paykel OB24SDPX1 Electric...
The oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Jul 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
