Question about Hitachi Televison & Video
Change voltage from 110 to 220 - Hitachi Televison & Video
    Guru:
  • 256 Answers
Hi. Normally, if you look at the back panel on your VCR, where all the inputs and output wires go, there should be a switch of some sort to change from 110v to 220v. Look for a voltage mark and sometimes a red switch which you can flip by hand, or sometimes a black swith which requires a flat tip screwdriver. (normally close to the power wire coming out of the unit). Hope this helps.
Posted on May 29, 2011
Testimonial: "Thank you, Micmort100 ! I didn't know if I had to unscrew the entire back panel to get to the voltage regulator. You saved me the trouble! Luv ya!"
Why is my alarm going off intermittently after being locked for no reason throughout the night and day?
Could be a drop in voltage. Alarms sense voltage change to trigger. When you open a door or cause any component to draw voltage while the alarm is activated it will trigger. Apparently something is drawing voltage or causing it to drop while you car is sitting. your battery may be going bad and the voltage is dropping past the benchmark level of the alarm trigger and it is going off. It can happen if the battery is marginal and it gets very cold out or there is a short in a component causing voltage to change.
Feb 12, 2015 | Cars & Trucks
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
My problem is voltage fluctuation, after starting generator the voltage is 380v and become 150v then goes up to 410v
I am sure the problem is the adjustment of the voltage regulator.
There are 3or4 small adjustable "pots" on the circuit board of the regulator.
You must connect an analoge volt meter to the output of the generator for this adjustment. Adigital will not work in this case. You will need to adjust the "IR" compensation pot as necessary to stabalize the voltage. This adjustment will surely change the voltage also. As you change the IR you will need to change the voltage too.
Let us know if you need more help.You may need to get the info sheet for your regulator if the pots are not cleasly marked.
Robert
May 11, 2012 | Caterpillar Electrical Supplies
Charger light stays red
Check the charger voltage and also the change in voltage when plugged into the unit. If there is no voltage at the terminals as required change/ check adapter, If there is voltage then the battery is faulty.
Feb 04, 2011 | Uniden Lands Phones
Currently i am using desktop computer celeron 1.7 Ghz which i am thinking to replaced by a P4(2.8 or 3.06) processor on the same motherboard. Apparently there is a voltage difference between 2...
If you motherboard will accept the P4 speed you want, you will NOT need to change anything. The board will automatically adjust the voltage when it sense the new cpu. I do recommend you upgrade your power supply that will support the voltage requirement. Most time when vendors build a pc with a low voltage cpu they usually use low voltage power supplies.
Check your motherboard specs, inparticular the voltage requirments and processor that are compatiable with your model board.
Good Luck.
C2Solutions
Jan 22, 2011 | Foxconn 661FX7MF-S Motherboard
How to change from 115 to 220 V?
In your pc backside have a option that 2 types of voltage. one is 110 and another is 220. so you can change your voltage from that.
Caution: if you change voltage that can affect your hardware contents . thanks
Apr 08, 2010 | Dell Dimension C521 PC Desktop
Monitor is black
This problem is high voltage.Your monitor can not create high voltage properly.Or power supply can not create strong voltage.Change filter capacitor or High voltage transformer.If have warranty life you can change or repair it from where you purchase it..
Dec 22, 2009 | ViewSonic VA1703wb Monitor
My 99 windstar headlights are dimming, the abs light has come on and at times will not start. van has a new battery?
Clean the battery terminals.
Check the alternator voltage.
Just start the van if you have to.
Check the voltage at the battery terminals.
It should read 13.8V to 14.2V.
If the pully tensioner is from 1999 then it's time to change it.
Check belt the cracks.
After the tensioner change and belt change then double the voltage.
It has to be 13.8V or high.
If not then change out the failing alternator,
Please rate my answer if it's helpful to you.
Cheers,
MUSTGO.
Dec 13, 2009 | 1999 Ford Windstar
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
