Question about Acer Aspire One Netbook
Monitor does not turn on when powering on - Acer Aspire One Netbook
  • 543 Answers
If it is working in dos mode, if you can see bios, change your windows system
Posted on May 29, 2011
Check video cable on computer
On the monitor unplug the power and video cable. Plug the power cable in, and then the monitor cable. Power off your computer, then turn on the monitor. After you power on the monitor, turn the computer on.
Nov 08, 2010 | HP 2009M Monitor
Power light on but no picture
check if the keyboard has light. If the monitor power is off, check the power of your monitor at the lower right side. Try to turn off/on the monitor and check if the "monitor going to sleep" message appears. Then interchange the blue cable (VGA) from one end to the other (in between monitor and desktop). Try also to power off your desktop, remove cables, then press n hold power button for 8 secs, and then reinsert cables back , and then turn on pc.Check if the monitor won't turn on. If still the same, replace your monitor by calling your pc manufacturer.
Aug 25, 2010 | Computers & Internet
The monitor won't go on after holding the power button
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 15, 2010 | Neovo F-417 17" LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    OSD locked how do I unlock
    OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
    Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
    Princeton VL173 scrren blank
    Sounds like the monitor took a power surge. Monitor is probably bad but try hooking up the power to the monitor on a different power outlet and see if it turns on, if not then the monitor is bad and would need to be replaced.
    May 04, 2009 | Princeton Digital VL173 Monitor
    Samsung syncmaster 753df power button no longer works
    check in back side of monitor reattch power cable after clean dust from it.
    also check with other power cable that your monitor turn on with other cable.
    Mar 21, 2009 | Samsung SyncMaster 753DF Monitor
    HP desktop monitor problem
    hi try this ,,,
    1. Ensure the video cable is connected (and connected to the correct video port).
    2. Turn off the monitor using the monitor's power button and then restart the monitor.
    3. Cycle the power on the monitor as follows:
    4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
    5. Unplug the power cord.
    6. Wait 5 seconds.
    7. Plug in the power cord.
    8. Press the power button on the monitor to turn on the monitor. One of two things happens:
      1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
      2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
      3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
        • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
        • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
        hope it will work for u .. little_angel
    Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Monitor
    -Turn off both computer and monitor
    -unplug monitor from computer(still plugged into power supply)
    -turn on computer and monitor(monitor is still unplugged)
    -After computer is on for about 30 sec. plug monitor into computer
    -turn off both monitor and computer(now connected together)
    -turn on monitor then computer and should be good to go!!!
    Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
    Acer Aspire One Netbook Logo
    21 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
