If I'm understanding this as what I think it is - that's not an error message at all! It's the input your recorder is currently set on (I'm talking about the "L2" shown in the right side of the LED display when the unit is powered on, where the channel number would usually be.) In order to change that, you have to open the bottom flap on the front of the machine (or slide open the remote bottom for the record controls to be exposed,) and press the "Input Select" button twice until it cycles through L3 and ends on whatever channel you last left it on - I think it defaults to 100 if the power has been interrupted. When you press this button after that, it would cycle through "L1", "L2", "L3", and the channel input (or coaxial cable input, to be exact), as expected. I know of no other "L2" message you might be speaking of. If I'm incorrect on this, I apologize. But I hope I'm not and that this simple issue is all that is causing you a headache! Good luck! And by the way, "L1,2, & 3" are the RCA/S-Video inputs on the back (L1 and L3) and on the front (L2) of your machine for various things you might plug in (video cameras, etc.) Note: For L1 and L3 ONLY, you have to go into setup to select whether you will be using the RCA yellow or S-Video jack on the back of the machine for the video of that particular input (with no bearing on the RCA audio jacks for that particular input - they're always used...) - the front L2 input evidently selects on its own between S-Video and the RCA yellow plug, based on which plug has something plugged in. I haven't tested to see which it will select if they are both occupied with a plug on L2. I don't mean to treat you like an idiot -- please don't take it that way - but I don't know how much you know about electronics, and IF I'm right about this whole thing, then I'm sort of assuming you aren't too familiar with them. In either case, please know that I mean well, and any information that you already know, just overlook. Thanks, and again, good luck!
