Question about Garden
Fuel not pumping through - Garden
  • 7,482 Answers
Hi jeffery22...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
I have 2008 GMC sierra 5.3 L with a new fuel pump. And no power to the pump. Any ideas where to look?
Fuel Pump Flow Control Module (FPCM) - LMF
The fuel pump flow control module (FPCM) is a serviceable GMLAN module. The FPCM receives the desired fuel pressure message from the engine control module (ECM) and controls the fuel pump located within the fuel tank to achieve the desired fuel pressure. The FPCM sends a 25 KHZ PWM signal to the fuel pump, and pump speed is changed by varying the duty cycle of this signal. Maximum current supplied to the fuel pump is 15 amps. A liquid fuel pressure sensor provides fuel pressure feedback to the FPCM.
Electronic Returnless Fuel System (ERFS) - LMF
The electronic returnless fuel system is a microprocessor controlled fuel delivery system which transports fuel from the tank to the fuel rails. It functions as an electronic replacement for a traditional, mechanical fuel pressure regulator. A pressure vent valve within the fuel tank provides an added measure of fuel pump flow control module (FPCM). Desired fuel pressure is commanded by the engine control module (ECM), and transmitted to the FPCM via a GMLAN serial data message. A liquid fuel pressure sensor provides the feedback the FPCM requires for Closed Loop fuel pressure control.
Fuel Pump Flow Control Module (Gas except LU3/LMG/LY6/LC9)
Mounted to the rear frame, near the spare tire mount
Wheels/Vehicle Underbody Component Views
Component Connector End Views
Fuel Pump Relay - Secondary (Gas with LY6)
On the fuse block - underhood bracket
DTC P0191: Fuel Rail Pressure (FRP) Sensor Performance
DTC P0192: Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
DTC P0193: Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
DTC P0230: Fuel Pump Relay Control Circuit
The engine control module (ECM) sends the fuel enable signal to the fuel pump control module (FPCM). The control module monitors the voltage on the fuel pump relay control circuit. If the control module detects an incorrect voltage on the fuel pump relay control circuit, a fuel pump relay control DTC sets.
DTC P0231: Fuel Pump Control Circuit Low Voltage
DTC P0232: Fuel Pump Control Circuit High Voltage
DTC P023F: Fuel Pump Control Circuit
DTC P025A: Fuel Pump Control Module Enable Circuit
Your best bet , take it to a qualified repair shop , dealer .
Mar 25, 2017 | GMC Cars & Trucks
How do i replace fuel pump 95 taurus 3.0 6v ohc
You must remove the fuel tank to replace the fuel pump.
  1. Remove fuel tank.
  2. Remove any dirt that has accumulated around fuel pump module retaining flange.
  3. Turn fuel pump module locking retainer ring (#1)counterclockwise using Fuel Tank Sender Wrench 310-D006 and remove fuel pump module locking retainer ring.
  4. Pull fuel pump module sender plate up out of fuel tank until locking tabs(#3) for fuel pump module are accessible. Reach through fuel pump module opening, squeeze both locking tabs together and remove fuel pump module from fuel tank.
Jan 10, 2017 | Cars & Trucks
How do I change the fuel pump in a 2009 GMC Acadia
drop the fuel tank and remove the circle lock. Youll see it when you take the cover off.
Feb 03, 2015 | GMC Cars & Trucks
No fuel coming to carburator
It could be fuel pump or fuel pump relay.Click here to see how to remove fuel pump.Click here to see fuel pump.See how much the fuel pump is,make sure it's that.Here's the fuel pump relay.Here's how to remove fuel pressure.
Dec 23, 2012 | 2003 Saturn VUE
Where is fuel pump for 1996 mercury mystique located on the car and how do you remove it
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Multi-Port Fuel Injection (MFI) Fuel Pressure Gauge T80L-9974-B
Removal
  1. Depressurize fuel system as outlined in Service Procedures- Fuel System Pressure Relief.
  1. Remove rear seat cushion. Refer to Section 01-10.
  1. Remove plastic grommet from floor pan.
  1. Disconnect fuel pump module electrical connector.
  1. NOTE: To disconnect fuel tubes from fuel pump module, compress tabs on both sides of each nylon push connect fitting and ease fuel tube out of fuel pump module.
    Disconnect fuel and vapor return tubes from fuel pump module.
  1. Turn fuel pump locking retainer ring counterclockwise using Fuel Tank Sender Wrench D84P-9275-A or equivalent and remove fuel pump locking retainer ring.
  1. NOTE: After fuel pump module removal, immediately cover fuel pump module opening in fuel tank in order to prevent fuel system contamination.
    Remove fuel pump module and cover fuel pump module opening in fuel tank.
  1. Remove fuel pump module O-ring seal and discard.
Installation
  1. NOTE: When cleaning fuel pump module mounting surface on fuel tank, use caution to prevent any foreign material from entering fuel system.
    Clean fuel pump module mounting flange and fuel pump module mounting surface and O-ring seal groove on fuel tank.
  1. Apply a light coat of Premium Long-Life Grease XG-1-C, -K or equivalent meeting Ford specification ESA-M1C75-B on a new O-ring seal to hold it in place and install it into the O-ring seal groove on the fuel tank.
  1. Install fuel pump module carefully to ensure that filter is not damaged. Make sure that locating keys are in keyways and O-ring seal remains in place.
  1. Hold fuel pump module in place and install fuel pump locking retainer ring finger-tight. Make sure that all locking tabs are under fuel tank lock ring tabs.
  1. Secure fuel pump locking retainer ring by rotating clockwise using Fuel Tank Sender Wrench D84P-9275-A or equivalent until fuel pump locking retainer ring rests against stops.
  1. Connect fuel and vapor return tubes to fuel pump module.
  1. Connect fuel pump module electrical connector.
  1. Install plastic grommet in floor pan.
  1. Install rear seat cushion. Refer to Section 01-10.
  1. Install Multi-Port Fuel Injection (MFI) Fuel Pressure Gauge T80L-9974-B as outlined in Service Procedures-Fuel System Pressure Relief.
  1. Turn ignition switch to RUN position for three seconds repeatedly (5 to 10 times) until pressure gauge reads at least 270 kPa (30 psi). Check for leaks at fittings.
  1. Remove pressure gauge, start engine and recheck for leaks.
Hope this helps
Aug 13, 2011 | 1996 Mercury Mystique
Location of fuel pump for mazda mx5 2000
Removal & Installation
Through the trunk servicing panel...
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Properly relieve the fuel pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Rear package trim
    • Service hole cover
    • Fuel pump cover
    • Fuel pump connector
    • Fuel hoses
    • Fuel pump and gauge sender unit as an assembly
    • Fuel pump from the sender bracket
To install:
  • New O-ring set
  • Fuel pump to the sender bracket
NOTE
Pull the fuel pump down so that it is tight against the bracket.
  • Fuel hoses
  • Fuel pump cover
  • Rear package trim
Oct 14, 2010 | 2000 Mazda MX-5 Miata
How to change a fuel pump on a 2005 Nissan
Nissan Car Altima & Sentra 1999-06 Repair Guide
Fuel Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Relieve the pressure from the fuel system.
    NOTE When the fuel sending unit needs to be removed, pull the tab upwards. The tab is located on the sending unit, opposite the end of the float. After the tab is pulled, the sending unit will lift straight out of the tank bracket.
    Negative battery cable Rear seat and the access cover Fuel pump electrical connector Fuel lines from the fuel pump assembly Locking ring Fuel gauge assembly Fuel tube and connector from the fuel gauge
    Fuel pump by pinching the 2 locking tabs together. Lift the fuel pump assembly straight upward and out of fuel tank. O-ring and discard
  4. Place a clean rag in the hole to keep out dirt.
To install:
  1. Remove the rag
  2. Install or connect the following:
    NOTE Verify that the mark on the fuel tank and the components are aligned when installing the pump and fuel gauge sending unit.
    New O-ring and fuel pump Electrical connection and fuel tube to the fuel gauge sending unit Fuel sending unit into the tank
  3. If equipped with a threaded lock ring torque the ring to 22-26 ft. lbs. (30-35 Nm). If equipped with a lock ring held by six retaining screws, torque the screws to 18-22 inch lbs. (2-2.5 Nm).
    Fuel lines and fuel pump electrical connector. Always install new clamps on the fuel lines. Negative battery cable
  4. Start the engine, check for leaks and repair if necessary.
    Fuel pump access cover Rear seat
The fuel pump is located in the fuel tank on all vehicles. In-tank fuel pumps are accessible by lifting up the rear seat to gain access to the inspection cover.
  2. Relieve the fuel system pressure.
    Negative battery cable Rear seat from the vehicle Inspection cover that is located under the rear seat Inlet and outlet fuel lines from the fuel pump assembly Fuel pump and gauge wiring connections 6 mounting bolts that secure the fuel pump assembly to the top of the fuel tank
  4. Raise up the fuel pump assembly and detach the fuel tubes and connector.
    Fuel gauge assembly Fuel pump with the fuel chamber
  5. Pull up the front of the fuel pump chamber and slide the chamber forward.
    Fuel pump from the chamber O-ring seal or gasket
To install:
  1. Install or connect the following:
    Fuel pump to the fuel pump chamber and slide chamber rearward Fuel pump with the fuel pump chamber Fuel gauge assembly using a new O-ring Fuel tubes and connector. Use new hoses and clamps. 6 mounting bolts to the top of the fuel gauge unit and torque the bolts to 18-22 inch lbs. (2-2.5 Nm) Fuel pump and gauge wiring connections New inlet and outlet fuel lines to the fuel pump assembly Negative battery cable
  2. Start the vehicle, check for leaks and repair if necessary. Inspection cover and the rear seat
Hope helps (remember comment and rates this).
Jul 07, 2010 | 2005 Nissan Sentra
How to change the fuel pump on a 1996 Pontiac Transport
For 1996 Pontiac Truck Trans Sport 3.4L SFI 6cyl check this procedure for Fuel Pump... there are two different electric fuel pumps used:
- A medium pressure twin turbine pump for vehicles equipped with Throttle Body Injection (TBI). - A high pressure roller vane pump for vehicles equipped with Sequential Fuel Injection (SFI).
(see Figure 1)
Fig. 1: View of the fuel pump assembly and related components
The fuel pump is mounted to the fuel sender assembly inside the fuel tank. The fuel is pumped to the engine at a specified flow and pressure by the fuel pump. Excess fuel is returned to the fuel tank by the return pipe. The fuel pump delivers a constant flow of fuel to the engine even during low fuel conditions and aggressive vehicle maneuvers.
CAUTION When working on or near the fuel tank, be sure to observe the information molded on the bottom of the tank.
  1. Disconnect the negative battery cable.
  2. Properly relieve the fuel system pressure.
(see Figure 2)
Fig. 2: Exploded view of the fuel pump-to-tank mounting components
  1. Drain and remove the fuel tank.
  2. Remove the fuel sender assembly.
  3. Disassemble the fuel pump strainer and the fuel pump: Note the position of the strainer in relation to the pump.
(see Figure 3)
Fig. 3: Remove the fuel tank locking ring with a non-sparking (brass) punch.
  1. Support the fuel pump in one hand, and grab the strainer in the other hand.
    1. Rotate strainer in one direction and pull off pump. Discard strainer.
(see Figure 4)
Fig. 4: Exploded view of the fuel pump components
    1. Remove deflector.
  1. Disconnect the fuel pump electrical connector.
  2. Loosen the two connecting clamps, if equipped.
  3. Place the fuel sender assembly upside down on the work bench.
    1. Pull the fuel pump downward to remove it from the mounting bracket, then tilt the pump outward and remove it from the connecting hose or the fuel pulse dampener.
  4. It is recommended to replace the hose and clamps, if equipped.
CAUTION Do not run the pump unless submerged in fuel
To install:
  1. Push the fuel pump assembly into the attaching hose. Attach the pump electrical wires and fasten the hose clamps to the attaching hose and around the pump body, where equipped.
  2. Place the fuel tank sender and pump assembly into the fuel tank. Use a new O-ring seal during assembly.
Hope this help (remember rated this).
Jun 04, 2010 | 1996 Pontiac Trans Sport
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
