Question about Epson Stylus Pro 4800 InkJet Printer
Epson Stylus printer
Hey Scrodamoon, I thought I would run this by you.
I was over at my sisters house. She has a Epson Stylus that isn't feeding paper anymore. I don't work on ink jets. I only do the laser stuff. I can get you a model number on the printer if you need it. The one I listed is incorrect. The utilities aren't working and the printer was moved about 100 miles back and forth within the last 8 months. That could have had something to do with I'm sure.
Switching USB ports didn't do anything. Printer indicates off line in the control panel. Intermittent on manual paper feed. Printer carriage does operate in all modes. Haven't been able to print on it yet.
Let me know if you have any ideas.
  • 1 more comment
  • Tim Babcock
    Tim Babcock Aug 17, 2008
    No grinding noise. No strage sounds. I think I might just try the cable. I left a message to her to get the model number. As soon as I get I will let you know.
    I wonder is the paper sensor broke or got messed up when it was moved?
    Thanks
  • Tim Babcock
    Tim Babcock Aug 25, 2008
    I finally got the model number it's a 740.
    The X1240 I couldn't get to download. My email provider keeps blocking me. I can post them to my ftp server for you though.
    Lexmark is being lame about some of their drivers.
  • Tim Babcock
    Tim Babcock Sep 03, 2008
    I had to go through a live chat session with lexmark to get them. For some reason there being selective about what Windows XP drivers to use.
  • 659 Answers
Well off the top of my head I would double check the usb cable. since the cables tend to get breaks in them when not fully stationed for long periods of time.
If you could give me the exact model of the printer it would be definatly of alot more help.
then I would be able to pin point a problem point with the unit but also what I would do would be to remove the paper roll and the paper tray and make sure that there is no jams.
last time it was working was there any grinding noises or abnormal sounds??
let me know and ill do my best to help you out on this issue.
thanks
Posted on Aug 16, 2008
  • 1 more comment
  • Wesley Gardner
    Wesley Gardner Aug 17, 2008
    thats what im pondering myself and possibly the sensor arm came undone? let me know when you get the model of the unit for me
  • Wesley Gardner
    oh hey again I see you sent the one person your email to give them the x1240 drivers if you have them you can email them to me at [email protected] and I will put them on my server more people respond to that better then the email thing for some odd reason.
    I am working on the hard to find drivers for certain printers and going to have them on my servers as well just cause it seems there is not that many complete driver lists on the manufacturers websites.
  • Wesley Gardner
    Wesley Gardner Sep 03, 2008
    ya if you have the link that would be great I wouldnt mind a copy for on my servers as well.
SOURCE:
Epson Stylus SX215 the ink cartridge holder won't move into position so I can change a cartridge
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Feb 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus c84 printer
hi try use this link
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=23953&prodoid=36033903&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=31&y=13
Oct 13, 2008 | Epson Stylus C84 InkJet Printer
Stylus pro 9800
you have left it on sheet feed what you need to do is press the button on the top which is furthest to your left until it shows the paper until the led panel shows a pic of a roll of paper with scissors
Oct 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Do I HAVE to have the CD-ROM that came with the printer to install it?
hey ther please click on the link below to go directly to the download site for epson and select your operating system in the menu to narrow down the stuff for you to download to get you going.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41664&prodoid=46253282&infoType=Downloads&platform=All
Aug 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Pro 4800 InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
