I need to change the hose for the cold water but cant access the connection to unscrew the bad hose the model is mav634aww maytag atlantis
    Problem Solver:
  • 6 Answers
If you can take off the Back panel, you should be able to access the hose from there
Posted on May 29, 2011
Testimonial: "Thank you it was a hassle but got to it :)"
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Maytag atlantis mav76000aww the cold water is coming out hot, i've checked the hoses and lowered my water heater temp, what else could cause this?
o know you say youve checkes your hoses,but try swaping them around see if that makes a difference!if it doz,nt get back to me,
Sep 23, 2011 | Maytag Atlantis MAV6000 Top Load Washer
CHANGE THE WATER VALVE ON A MAYTAG ATLANTIS WASHER
Unplug the washer
Remove the hoses.
Unscrew the water valve
pop the top.
This manual shows
the procedure
on page 21
Apr 19, 2010 | Maytag PAV3240A Top Load Washer
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
COLD WATER
3 suggestions. 1st, make sure all of your valves are open. (some times installers forget to open them back up after the install) 2nd, fill the machine until the water gets hot. Check on the rear of the machine and make sure the hose going to the "COLD" valve is not hot (somtimes these hoses are reversed when they are installed) if those are both ok, then 3rd shut the water off and unscrew the cold side hose. (There is a screen underneath that can get covered with sediment from the house water supply and cause the water not to flow)
Jun 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Slow cold water
1.) turn off water valve that supplies cold water to washer.
2.) unscrew the cold water hose-type connector immediately next to the set of 2 water connections in back of unit.
3.) look into the hose you just removed or into the water connector on machine. you will find a metal screen (like a window screen) that is cone-shaped...if none found then remove hose connection at other end of same hose...remove it and then clean it thoroughly and then re-assemble all.
Nov 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer is a bit older its a Dependable Care model 3cycle
The agitation problem is probably caused by a bad timer. Also, on the wrinkling issue, be sure that your hoses are connected right (hot to hot, cold to cold). Have found out that if they are switched, you would wash in wrong temp. Doubt that a hose would cause problems because washer wont start unless the proper amount of water is in the tub (also could be a timer problem). Good Luck!!! Jim
Sep 08, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
