Question about D-Link Wireless
We're using our d-link wireless router and have tried adding a new computer. When I enter our password/network key (10 digits) it will say that it is connected, yet when I go back in, the password is only (7 digits) and it never connects to the internet unless I tell it to disconnect and then reconnect. We've tried changing it through "Network Connections" but it never saves the correct password/network key. I know that I've had this problem in the past and there was another way of putting it in where it saved the full/correct network key but don't remember how to access it. Any help would be much appreciated. Vicki Walchuk
  • 102 Answers
SOURCE: changed router to airport extreme - no connection
bayoubill:
I am sure that Airports are WPA compatible. You manually put in the key of WPA or WPA2 in the router itself (in your case since you changed the router so please put in the key onto your aiport) make sure that this key matches the key onto the clients workstations or laptops.
Let me know.
Thanks
Posted on Dec 20, 2007
oldnovii
  • 667 Answers
SOURCE: wireless secured network key code
Hi BabyDoll - to find your key, log in to your router. Enter 192.168.0.1 into your browser. If the defaults haven't been changed, the user is " admin" all small case without the quotes. There is no password. Just enter the user and leave the password blank. To get the key, click on the wireless button on the left. Then look down the page and you'll see the passcode fields. This is what you're looking for. Also take notice of what's above it such as WPA, WEP, etc. Write this info down. You can also go into your pcs that you use wireless on and put that key in and the kind of security (WPA, etc) so that it will not ask for it every time.
If this solves your problem PLEASE rate this as fixed. If not, DON'T RATE YET. Let me know what happened and I'll be happy to assist you further. If you need to know how to enter the info so that you won't have to enter it all the time let me know. I'll help you with that. Let me know what happens. Thanks.
Jeff
Posted on May 22, 2008
sandeep239
  • 59 Answers
SOURCE: Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Posted on Jun 03, 2008
SOURCE: d-link DIR-635 router
How I have solved my problem with the wired computer to a DIR-635 router:
- downloaded latest firmware from ftp.dlink.de/dir-635/driver_software (as posted here before)
- reset the router ( keep just the power cable connected to the router, press the reset button and switch off/on while holding the reset button pressed, off/on again with reset pushed down, release reset button, connect LAN cable between PC and router, access router 192.168.0.1 and all the configuration using the wizards)
- while configurating your Internet connection (I have the wizard option) it is important to use the option "clone MAC address from your PC", the one you used to connect direct to the cable modem.
- Follow next common steps to configurate your wireless network, etc.
Right now I'm having my PC wired to the router plus three other desktops via wireless and a wireless Canon printer.
Everything is working fine, no network drop, no internet drop. Perfect as it used to be.
Posted on Jan 06, 2009
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Posted on Feb 27, 2009
Iphone 4s will not accept password to d-link di-524
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.
Jul 15, 2012 | D-Link AirPlus DI-524 Wireless Router
I have a new Netear Router & I'm trying to hook up my Kindle which wants a password
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 26, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
I just bought a wireless router netgear N600 and I have problems trying to connect it to my samsung tv (using a samsung lan adaptor model WIS09ABGN) On the TV screen you can see the network, but when I...
Well it seems to be an issue with the security setup on the wireless router. Please perform the below task to configure the settings on the router:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
Please connect your TV to the network using the password as set above.
Regards
Anand
Oct 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
The laptop cannot connect to the wireless router
First make sure wireless driver installed on laptop and working fine. Go to network connection property then make sure it is enabled. Make sure wifi is turned on laptop press Fn key +F5 key to turn it on. Also make sure wireless on router is enabled. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security then enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 01, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Please,please help me: I have a att WIRELESS 2WIREGATEWAY, IT'S ALL CONNECTED WITH ALL "GREEN LIGHTS on & STEADY, EXCEPT THE "WIRELESS" LIGHT WHICH IS NOT ON, MEANING IT NEEDS TO BE...
If the wireless light is off that means you are not connected wireless to any wireless device or computer . Once connected wireless to anydevice then the wireless light will be on. Make sure the wireless is enabled on the modem .
1. use a hard wired computer - open internet explorer
2.the address box(url box) type 192.168.1.254 without any http:// or www
3.You will find a network at a glance page - click on home network icon on top
4.right side you will see the wireless status: enabled or disabled . here make sure is been enabled
****** Some time modem ask for enter system key or password . there will be a link says i forget the password - you will find a hint , try your password , if failed to get that also then click another link there "i still cant remember my password " . and you will get the box for enter system key , enter new password and confirm new password . now the system key in the 10 digit key on the white sticker below the bar code on the bottom of 2wire modem and new password is all yours.*******
Aug 14, 2011 | 2wire (2701HG-B) Wireless Router
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
How do I find the current passworsd?
In order to get the password key we need to login to the router's page using any computer which is physically connected to router. Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase (or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Regards
Anand
Apr 09, 2011 | NetGear WGR614 Wireless Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Nintendo wii will not connect to my new d-link dsl2640r router
To connect the Nintendo Wii to your wireless router, the following settings must be set to the router.
*Wireless Network Name (SSID) - must be one word
*Wireless Encryption/Security - must be WEP
*Network Mode - must be Mixed
Open your router's admin page using Internet Explorer and type http://192.168.0.1 and type your router's password. By default username is admin and password leave it blank.
When you get to the router's setup page, look for wireless tab then change the Wireless Security Mode to WEP 64-bits/10 Hex digits. Type in any 10-digit hexadecimal key on Key 1, then save your settings. You should remember the 10-digit key because you'll going to use it on your Wii settings.
On your Wii settings, try to reconnect to wireless network then type in your 10-digit key. That should do it.
Jul 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
