My washing has an odd smell after washing, i use the (40degree cycle mostly) i want to clean the filter but can't find it?
    Brigadier General:
  • 6,277 Answers
It is always advisable to run a 90 degree wash occassionally as that should kill bacteria whereas 40 degree washes apparently do not!
As you have not mentioned the make or model of your machine here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 29, 2011
Washer says no water on most cycles so I'm unable to use the clean washer cycle to get the smell out
What exactly is your concern? Are you not getting enough water to start any cycle? Or are you trying to sanitize and clean the unit before a full cycle use?
Jul 31, 2012 | Frigidaire ATF6000ES Front Load Washer
My Wash smells musty
In most Owner's Guides for front load machines, manufacturer's will advise to keep the door open after almost every cycle to help evaporate the water in the unit. Also to clean the rubber door seal with bleach water. To get rid of the smell there are solutions on the market that you can throw into the tub when you are not washing clothes and run a hot cycle. You can also use bleach, white vinegar and lime juice as an alternative. Then run a hot cycle. Do this about every 2 weeks, and keep your door cracked.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
My indesit washing machine doesnt seem to be washing clothes they come out still dirty after a 40degree wash and sometimes dont smell nice. I put a tablet in the drum & loads of conditioner &...
indesit washing machine doesnt seem to be washing clothes they come out still dirty after a 40degree wash and sometimes dont smell nice This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 15, 2011 | Washing Machines
Hi, The last two washes i've just done on my Hotpoint WD72, the washing has gone full cycle but has come out smelling damp. Any ideas? I've had it since 2005 when it was new.
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 26, 2011 | Hotpoint Ultima WD72 Front Load...
Washing machine drum always smells of stale water. Have tried hot washes, washing machine cleaner kits, cleaning filters, leaving door open, have also checked machine is correctly plumbed in but cannot get...
Jul 12, 2011 | Whirlpool Washing Machines
I have a Tromm Washer and Dryer. Washer cycle time taking twice as long as time on indicator. Mildew smell still there after I have cleaned filter and run wash cycle. Drum vibrates horribly on spin...
You may have a problem with the motor sensor. Replace the motor sensor and it should take care of the problem. As for the mold issue, purchase some washing machine cleaner and follow directions. It should take care of most of the smell issue. Good luck
Jun 21, 2011 | LG Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
Washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jer
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Scum on my clothes espically whites help
you need to do more washs on 90 but dont put bleach in its just sludge build up between the drums vey normal ffrom doing warm washs all the time i do 95 degree washs evey three months to keep machine clean.hope this helps.
Mar 26, 2008 | Zanussi FJ1454W Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
