Question about D-Link DIR-600 Router
My Dlink DIR 600 can provide wireless access to my laptop and to my PSP but not to any of my phones. I tried checking the Broadcasting of the SSID - (enabled) but still if I try to check the SSIDs broadcasted. There's no wifi connection found. I tried my two Nokia 5800 XM phones - no good I also tried our other two Blackberry phones - no good Help.... Even the DG is not working.
4 Suggested Answers
  • 49 Answers
SOURCE: not broadcasting
Try reconfiguring your wireless setting from your router. Create a new wireless network. The old setting may had been corrupted.
Posted on Jan 04, 2009
  • 18 Answers
SOURCE: I have a DIR 615
Ok this might be a bit tricky but it sounds like there is another wireless signal that may be interfering with yours.
Do you have an older cordless phone in the house? If so try and move the cordless base farther away from the wireless router. Even if they are on different floors in your house, if they are located near each other the cordless can interfere with the wireless signal.
The other possibility is that there is signal that is coming from the outside of your location and is causing the interference.
I know that when I had an XP Pro machine (Laptop) it would drop the wireless signal every couple of days or so. I traced my problem to my neighbors cordless phone. he had an old one and it was near the side of my house that my router was on and it was causing me problems so I move my router and the problem went away.
hope this helps
Posted on May 21, 2011
  • 56 Answers
SOURCE: I have a D-LINK DIR-655
Try resetting the router back to default settings. Press and hold the reset button for 10 secs. then release. After the reset, try accessing once again and check if you have the complete details on your wireles LAN section.
Posted on Sep 04, 2011
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual:
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I cant connect my wireless dlink dir 600 to wireless connection
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Aug 26, 2011 | D-Link DIR-600 Router
The dlink dir 600 wireless router seems to provide me intermittent connection i tried checking the cable connections from modem to router and everything is fine. i tried to ping the DG but i...
If you have two routers in the network (the cable router and your own router), make sure you only use one dhcp. If you use two, it make thing more complicated. To test the router you should properly disconnect other connections that is not being tested. Finally try to reset the router to factory setting. If you are using USB Network device, make sure the USB port provide enough power to power-on the device. Double check the key....Good luck
Jun 21, 2017 | D-Link DIR-600 Router
Both my PC and laptop were not able to connect to internet and I am using a dlink wireless router, what could have caused it?
Please do the wireless settings i.e configure SSID & encryption key in DIR 600.
After that connect laptop or pc wirelessly with same ssid.
Mar 25, 2011 | D-Link DIR-600 Router
I am trying to add a password and network name to my wireless router. I have access to the internet, but it's an open connection called DLink. The router is a DIR 625.
To secure your wireless network from unauthorized access, including changing the default SSID from Dlink to something else. Please click in this link and follow my instructions :-
Aug 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-600 Router Logo
42 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
