Question about Electrical Supplies
Our old (maybe 20 years?) Mistral 2 setting strip heater string has broken. When I dismantle the switch, there are bits everywhere (well, 3 bits) and getting them back together would be easier if I had a picture as they make no sense to me. I assume there is a pawl and catch but I cannot figure it out. I assume the switch is probably replaced as a unit, but I have it apart now. Any ideas or help appreciated.
Noggin
  • 944 Answers
SOURCE: Bissel Proheat 7901 Diverter Knob and Flap problem--Helpppp!
Manual here in case you missed the link; http://www.bissell.com/images/UserGuides/7920.pdf Waiting on your photo as discussed. :)
Posted on Mar 14, 2007
SOURCE: Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Posted on Aug 17, 2007
  • 508 Answers
SOURCE: replacing a heater core
YOU DO NOT NEED TO REMOVE THE DASH BOARD. IT WILL BE BEHIND THE GLOVE BOX. LOOK UNDERNEATH THE DASH AND YOU WILL NEED TO REMOVE A PANEL TO GAIN ACCESS TO THE HEATER CORE. THE PANEL WILL BE ABOVE THE PASSENGERS FEET ON THE FIREWALL.
Posted on Jan 24, 2009
muttandjeff
  • 359 Answers
SOURCE: rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Posted on Feb 23, 2009
  • 38 Answers
SOURCE: HP PAVILION ZV6000 LAPTOP CMOS BATTERY LOCATION
You have to take the keyboard off. Gently pry the plastic strip that is between the top of the keyboard and hinges. Unscrew the (2 to 4) screws holding the keyboard down. Slide the keyboard up and out. You should see the battery with 2 wires going to the motherboard. Pull the battery connector off the board, take out the battery and wait for about 30 seconds. Replacing it is easy once you have it open.
Posted on Mar 24, 2009
My printer is refusing to print.it makes a deceptive sound that makes one to think printing is on but to no avail.please i need urgent help.
along the top of the unit behind the cart is a plastic strip
its a vernier strip its lots of ''''''''' all the way along
the print head uses it to know where it is
i think either the sensor that reads the strip {ir TXRX led }
or the strip is dirty or worn
Jan 10, 2015 | HP Photosmart C4480 Color Printer Scanner...
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Jan 06, 2015 | Heating & Cooling
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK...
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
May 24, 2011 | Dimplex CS3311 Compact Heater
I have been working on an older Lennox furnace that continues to give me problems.The burners will stay lit appr 2 to 5 min and the go out even when there is still a call for heat.I have cleaned the...
could be the box not sencing the flame i take there is not pressure switch on the model you could jump out . check the fan settings on the limit are set right
Jan 20, 2011 | Heating & Cooling
I have a string of 20 batteries on an MGE Galaxy 3000. 3 of the cells tested bad on the last PM. The batteries are 3.5 years old and operate within the temperature limits suggested by the manufacturer....
It depends on the manufacturing battery life time. Generally they are 3 to 5 years or 5 to 7 years or 8-10 years. Nevertheless due to high cost of batteries most client opt for use 3 to 5 year life time. A simple internet search will give you the specification and from there you can decide what to do. If it is 3 to 5 years life time it is advisable to change the whole set. Otherwise you can replace the 3 batteries as a temporary solution. However it is most likely that after 3 to 6 months you will have some other bad cells.
Jan 19, 2011 | MGE Galaxy 3000 UPS System
Pilot wont stay on furnance in the garage. About 20 years old
clean pilot and change thermocouple see if this works
Jan 07, 2011 | Dayton Gas Furnace Heater
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Having a problem with a heater i bought
I have the same heater and when that happens just unplug it for about 15 minutes and plug it back in and it should work fine. It only does this for me when I am using a extension cord or a power strip. It needs a dedicated power supply (wall outlet) with nothing else attached. If you must use a extension cord I have found that the heavy gauge orange power cord is the only one that does not overheat and causes the heater to shut off. The heater comes with a 3 year warranty, the longest warranty I have ever seen with a heater.
Mar 25, 2008 | R.A.M. Computers LASCO-5540 Ceramic...
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
