Question about Canon PowerShot A450 Digital Camera
Data not transferring from camera to computer
  • 977 Answers
Hi!
If you're having problems connecting the camera to the computer to download photos, the easiest solution will be connecting the memory card directly using a card reader!
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Posted on May 29, 2011
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jul 07, 2013 | Samsung DigiMax Cameras
DOWNLOAD DRIVERS FOR SVP MP-585 DIGITAL CAMERA for WINDOWS 7
HelloYou dont need any drivers for this product, when you attach camera with computer it will automatically recognize and install, other way to transfer data from camera to pc is the use of card reader and transfer data.
Hope this helps
Oct 03, 2011 | Cameras
How do i transfer photos onto my computer ?
you would be having a data cable provided with the camera... plug it in to the camera as well as the computer USB port. install the camera drivers (generally not needed) and you system would recognise the camera, after this you can transfer the images from the camera to the computer.
Mar 12, 2011 | FUJIFILM FinePix J40 Digital Camera
My camera will not allow me to take videos. And I cannot figure out how to upload pictures from camera to computer. Please help.
you should be able to transfer pictures from your camera by connecting the data cable to camera and pc and select the data transfer mode (if this mode will not be automaticaly selected) , and for video recording you should select the video function from your camera and should work
Dec 22, 2010 | Nikon Coolpix S4000 Digital Camera
How do I transfer my photos from camera to computer - out of town with no manual
First of all computer need compatible camera driver/software to communicate with your device (camera), you can download camera driver from its manufacturer's (camera) website. After installing camera software/driver into your PC (Computer). Connect your camera with computer through USB Cable that came up with the camera and transfer photos.
Thanks...!!
Nov 18, 2010 | GE X5 Digital Camera
Can I transfer photos on my computer back to my camera memory card?
Hi friend,
Yes you can....you tranfer photos between computer and camera. but you need to be use cable for it..otherwise you can't transfer data without cable
Dec 20, 2009 | Olympus FE-330 Digital Camera
For some reason I can not get my pictures to transfer to my computer from my Canon A560 camera. It has worked in the past. Any suggestions? Mary
I have the A570, which is fairly similar, and I use one of two methods for transferring pics from the camera to the computer. One is to use a USB cable between computer and camera, and the other requires removing my micro SD card and plugging it into a card reader. ( I purchased micro SD cards with SD adapters so I can use the second method.) Using the second method allows you to view the data just like you would any other data on your hard drive. If you don't have a card reader, maybe a friend does? At this time, I don't know if there is a problem with the camera/computer connection, or the data card. Re-post with more detail regarding what you do to transfer, and whether you get any error messages, if this doesn't help.
Nov 22, 2009 | Canon PowerShot A560 Digital Camera
Where do I connect my camera cabel to my computer?
Some cameras have a multi-use cable which can be used for both data transfer or copy, and video output. Most cameras I have worked with usually have two cables, one for video playback and the other for data transfer or copy to a computer or other device. Most all cameras today use the convince of the standard computer USB access.
Most cameras have a cover made of either rubber or plastic which can be folded back to reveal connectors for mini-USB and video outlets. The appropriate cables must be used to connect to video or a computer or other device.
It is advisable to read your user manual for information on usage of the video and the data transfer cables and the software, if that is what you need.
I also suggest to skip all that and use a card reader, no more hassle. A card reader will give you more freedom without having to install software to see your photos or other files.
Nov 08, 2009 | Canon PowerShot A570 IS Digital Camera
HOW TO TRANSFER PICTURE FROM CAMERA TO COMPUTER AND I DONT HAVE DATA CABLE TO TRANSFER ANY KIND OF DATA AND ALSO WANT TO KNOW HOW TO TURN FLASH LIGHT ON
well you can either buy the data cable or if you have a memory card slot on your computer then you can take out the memory card in your camera and put it in there. and the user guide is in this link.. http://www.fixya.com/support/p10366-largan_chameleon_mega_digital_camera/manual-18010
Aug 14, 2009 | Largan Chameleon Mega Digital Camera
Video/PC firewire transfer
have your pc updated with klite mega codec pack so that youll be sure that the data from your camera will be shown on your computer.
you can also try and use picasa 2 from majorgeeks.com
this will help you identify where your pics and vids are on your computer.
Mar 12, 2008 | Cameras
Canon PowerShot A450 Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
