Question about LG Flatron L1750S 17" LCD Monitor
Why does the monitor not display when the computer is turned on? It comes up with Analogue Powere Saving Mode and then blank again? I have rectified it now after 36hours hassle. Can you tell me what to do if it happens again? thanks
    Scholar:
  • 101 Answers
The only thing that comes to mind is pushing the source button on the monitor, or finding the source option in one of its menus. If it is on analog and is not displaying an image, you may have to switch it to Digital or DVI, depending on what type of cable you're using to plug it into the computer. Though this is usually auto detected by the monitor when the computer is turned on, unfortunately there aren't many options when dealing with a monitor that refuses to post an image.
Posted on May 29, 2011
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
THE COMPUTER IS IN A POWER SAVING MODE
I think you mean, your display is in power saving mode, this happens when there is no signal from the computer - the display then goes to powersaving mode, try restarting your computer, if it doesn't turn on the display. try the display on another computer to see if your display works.
if your display works with anohter computer, try it again on the problem machine, if its still in the power saving mode, then its not turning on, the computer is not turning on-
I would suggest to get a local friend or a tech to look into your computer and find the issue, if your handy with screwdrivers and know your way inside the computer, then you could take the case open and reseat the memory. try without any memory, then try with just one memory module. Then put them all back in, if this doesn't help, its not a memory related problem.
to save time i recommend you take the computer to a local professional.
Jul 15, 2009 | LG L1915S 19" LCD Monitor
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
How to temporarely disable analogue power saving mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 13, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: http://us.lge.com/filedown.do?filepath=1000000757&fileName=L1750B-BF.pdf Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Jul 30, 2007 | LG Flatron L1750S 17" LCD Monitor
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1750S 17" LCD Monitor Logo
138 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
