Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
9 pause 1 blink code rcahd52w59 - RCA D52W20 52" Rear Projection HDTV-Ready Television
    Genius:
  • 1,030 Answers
This blinking is unfortantly not an error code. The one thing that you can determine from this blinking is that the main fuse. and the sub power supply is functioning. The blinking is also an indication that the cpu of the set is getting power.And its not simply a fuse.What is happing is some voltage or current is not right and the cpu is taking the set into shutdown for safety. In diagnoseing these sets first uplug the set and allow them to set for som time. not that long. Then plug them in and attempt to turn it on again. DID you hear a click? how about some high voltage static. The most common faliure of these sets that i have seen at the shop is the faluire of the high voltage transformer known as the flyback and when this fails it also takes what is known as the horizontal output transistor. The cpu will shut down the set for about 25 different reasons. Technicians have a computer interface that they ussally use to diagnose the problem
Posted on May 29, 2011
I have a 91 Buick Century that dies after a few minutes.
Fuel or ignition problem? Right after it dies, check for spark at a plug. A bad coil will often work till it's warmed up, then fail. If you still have ignition spark after it dies, or if it starts right up again, then it's something else.
Check the fuel pressure to make sure it's at proper pressure. Also scan the computer for any trouble codes that are related. It's easy on your car if you understand how the flashing light translates to two-digit number codes. Use a wire or paperclip to bridge terminals A and B of the diagnostic test connector protruding out from bottom of dash. It's a 12 pin connector. A and B are the two upper right terminals on it. Now turn key on and the check engine light will begin blinking the codes. Code 12 is diagnostic mode-one blink, pause, pause,blink, pause blink. See? 22 would be blink, pause, blink, pause, pause, blink, pause, blink. See? 33 would be three blinks, short pause and then 3 rapid blinks. (I"m going blink crazy!) Well, get the codes-they are two digit codes, and will keep repeating, lower numbers first and in succession, over and over while in diagnostic mode. Maybe an idle sensor fault will show up.
Good luck.
Dec 06, 2011 | Cars & Trucks
Blink pause blink blink with a GM code reader for 1982-1995 domestic cars and trucks reads ecm and abs codes , what is the blink pause blink blink code/
each blink indicates a character for a particular code (letters, numbers etc.). Take the vehicle if possible to a mechanic or auto parts dealer and have a diagnostics test performed. This only takes a few minutes and is usually a free service at a auto parts dealers (Napa, Baxters, that I know of).
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Apr 28, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
I have Dish Network Remote but there is no LG TV Code. How can I get?
8006
Thats a goldstar code and the buzz on the web is it works 50% of the time.
I just found this as well never tried it but it may work good luck
you want to know the code to put in just do these steps:
1. press and hold the tv button till the all the top buttons turn red
2. press the # button twice
3. the tv light will blink out the code to you. It will blink the first number then a pause then blink the 2nd number then a pause then blink the third number. For Sony2.gif you will see 5 blinks, pause, short blink, pause, short blink. (short blink means a zero) the code for sony is 500
4. Thats it!
Sep 14, 2009 | LG 50PX5D 50 in. Plasma HDTV
Car almost didnt start then s light blinked the
The 'S' light is also your diagnostic indicator....so, the answer lies in the 'sequence' which the S light blinks.
Codes:
Long blinks: 1st digit
short blinks: 2nd digit
e.g.1 - if there are 6 short blinks (followed by long pause) then repeats 6 blinks again, the code = 6.
e.g.2 - if there is 1 long blink, then 4 short blinks (followed by long pause) then repeats again, the code = 14.
The ECU may show more more than one code.
Once you determine the correct code/s, post them here so someone can assist you further.
Cheers,
Aug 12, 2009 | 1991 Honda Accord
RCA D52W19BYX2 power light blinks once pauses, blinks a 2nd time, pauses, and blinks a 3rd time. Wait about 65 secs and it will do it again. Happens whether I use the remote or the switch on the set. Also,...
try unplugging the tv overnight, then plugging it in when you want to watch it.
i guess there is some safety switch on the processor inside the tv itself that kicks itself on...stupid.
that is the only "band-aid" i have found that works
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Hello
What that means is that the set doesnt recognize any shutdown error if it does 1blink short pause the 2 blinks, but if it does 2 blinks short pause the 1 blink thats an error code. can you dtermine which sereies of blinks it is?
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
1999 Sony Trinitron TV. We have sound but no picture. Stanby light is flashing?
How many times does the light blink. It should blink a code 1-8 blinks pause a second then blink the code again. Count the blinks then let me know. If it just blinks constantly without pausing. let me know that as well.
Jan 19, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
