HiGrade Notino uL100, Missin Hal.Dll. Tried recovery, dosen't work. Any tips?
  • 543 Answers
If recovery does not work , you need install windows system again.
Posted on May 29, 2011
No arranca windows por el problema de windows root\system32 \hal.dll.
Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini DEL C:\Boot.ini BootCfg /Rebuild Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | MSI Wind U100-030US Laptop
My notino ul100 will not reboot even after the F7 procedure
Remove the hard drive this is very easy. Connect to another pc running xp using a USB caddie. On the notino drive check the windows directory. If you that there are no files only folders then copy explorer.exe to the windows directory. Restore HDD to Notino. Recovery using F7 should work now. This is because the Higrade recovery uses the file explore.exe to validate the destination drive for recovery ( even if file explorer.exe is blank file) This can also be done without removing the HDD. When you get to the screen with the two GREEN pointers move it aside and you will see a dos prompt. Copy explorer.exe from a USB memory stick to D:\windows\ the usb stick should be drive G: Then reboot. It works honestly good luck Switcher
Oct 24, 2010 | Computers & Internet
Recovery cd here is what show up when i turn on
You did not mention what is the manufacturer and what is the operating system you have but you can try following:
hal.dll is the file which protects your hardware devices to access the memory directly. HAL ( Harware Abstraction Layer).
To repair hal.dll we would require the recovery discs else you can try recovery console in your computer
1. press the power button and keep tapping on F 11 for HP computer and ctrl+F11 for Dell computer
2. check if you get a Recovery Manager
3. you can perform a recovery from here
May 18, 2010 | HP Compaq Presario 2200 Notebook
Motherboard 400M01 series - windowsroot\system32\hal.dll corrupted - don't know how to recover system from this error. It won't reboot - tried hotkey super recovery,etc. Nothing helps - my knowledge is...
Here's a very useful page which explains how to troubleshoot this error:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
Go through the list of suggested solutions. One of them should fix your problem with the corrupted hal.dll
Dec 03, 2009 | Foxconn Computers & Internet
My notino uL100 notebook laptop isnt working! PLEASE HELP!!!
Do you get the message to press f10 at all during the boot process? If so please press f10 and follow the recovery procedures. All Hi grade systems without disks have a recovery partition built into the hard drive and you access this via the F10 key during boot up. Please let me know how you go with this.
Jul 28, 2009 | Computers & Internet
The webcam dont work anymore
Okay, the driver for the webcam (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the webcam application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the webcam driver, and the problem will be fixed!
Mar 13, 2009 | Acer Aspire One PC Notebook
Missing file when computer is turned on
hi, hal.dll file to communicate with your computer hardware. if you are able to goto command prompt then do the following :
ensert your cd into the cd drive asuming that d is your cd drive then do the following :
and press y when prompted.
alternate you have to reinstall the os.
Jul 22, 2008 | HP Pavilion (PN153AAR) PC Desktop
Compaq pc recovery problem
hal.dll is a dynamic-link-library.
Not necessarilly a part of your operating system.
could be a printer or other peripheral device driver.
try re-installing all of your other hardware device drivers.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
