Question about AOC Monitor
The monitor has suddenly, the day before yesterday, turned very bright and there is a long "ghost" image of the previous screen. I have not changed any settings! Yesterday it went back to normal - but today the problem is back! Any help would be much appreciated.
    Scholar:
  • 101 Answers
Unfortunately it sounds as though your monitor is slowly dying on you :\ Though i must say its a very strange way to have it go.
Posted on May 29, 2011
Acer aspire l320
In a bright light do you see a "ghost image" on the screen? Have you tried a External Monitor? This may help: http://www.youtube.com/watch?v=2Yi6GNFcP3w
May 24, 2013 | HP Mini Computers & Internet
I have a syncmaster 740B monitor with ghosting problems. Have tried adjusting via the monitor controls, including reset & auto but to no avail. Resolution is set to 1280 x 1028, 32 bit. Other...
Try with a lower Screen Resolution and/or a lower Screen Refresh Rate.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Computers & Internet
Toshiba satellite A505D-S6968 I turn it on and everything lights up but I get a blank screen. Nothing at all the keyboard is lit up and so are the power buttons
Can you see anything on the screen in a bright light? A ghost image? Fan spins? Sounds? Only a black screen? Has there been ANY damage? Drop? Bump? Jar? It could be the Monitor, Inverter, backlighting, lose connection in the rear of the monitor, the switch the controls the lighting of the monitor when you open and close the lid? Hard to be sure without troubleshooting. Here's a video to give you some tips: http://www.youtube.com/watch?v=2Yi6GNFcP3w
May 12, 2013 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
I can't turn start the computer the screen is just black
Has the computer been dropped, jarred, etc. Are you getting a "ghost image" on the screen in a bright light? With little info, it could be backlighting, lose connection, monitor, ribbon cable, etc.
Dec 05, 2012 | Dell Latitude E5500 Notebook
My screen does not come up when I turn on my computer? Black screen
You didn't give much info, Make, Model of computer, your OS? Has there been any drops, bangs, jars..........etc. of the laptop? Can you see a "ghost image" on the monitor in a bright light? Has it been overheating? Need more info.
Dec 03, 2012 | Computers & Internet
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
No picture on Phillips 20in TV
Your previous adaptor may have been damaged by the failure of an internal component in the set.
Look at your LCD screen from a shallow angle to see if you can spot any 'ghostly' images on the screen when it is turned on and has audio present. If you can, then either the fluorescent backlight has failed or the circuit that produces its high voltage. I've yet to see a modern set that even allows the brightness to be turned down so far that no image is present.
Your grandson may be 'off the hook.'
Jan 15, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Computers & Internet Logo
231 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
