Question about Refrigerators
Was cleaning it. didn't turn it off. now not working. have i burnt out the motor? if so, where can i get a new one from? thank you for your time
    President:
  • 2,468 Answers
Your ptc overload on the motor/compressor is all thats wrong unplug this part off the compressor and get an exact replacement
Posted on May 29, 2011
I have a ken more elite double oven. I set it for 425 for 30 min and was to turn it back. I am cooking a chicken. I didn't have my glasses on and accidentally turned the flex and clean on. Now
sure you'll be able to open it but your chicken will be burnt to a crisp. actually, it may not if you just hit cancel right away after starting the self clean feature.
Nov 14, 2012 | Ovens
Model number ffhs2313lp3 light burnt out got a new one wont work
if you new light still didn't work . so what's the problem ? maybe the light was in good condition . did you check you circuit board ?
home light bulbs
May 31, 2012 | Frigidaire Refrigerators
While 1/2 way through vacuuming my carpet, my Dyson 28 stopped picking anything up and started to smell like burnt rubber. I cleaned the roller on the bottom and spun it around to check the rubber belt. ...
I'm sorry to hear you're having difficulties with your DC28. Since you've checked for an obstruction, but have been unable to resolve the issue, it's probably best if you get in touch with us directly so we can provide the support you need as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
MY TV REMOTE IS NOT WORKING ?
Check the battery of your remote.Try to replace new battery.If didn't work.Try to open and clean the contact of the bottun of the battery.If didn't work, its need to replace the crystal of the battery.Try this sugestion.Thanks
Aug 26, 2011 | Sony KDL32EX700 32 in TV
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
So, i have a brand new battery, and i replaced the starter relay which is located at the other end of the positive (red) wire coming from the battery. when i turn the key on, lights and everything comes...
G'day.I can help you with this.The clicking noise is the starter relay(solinoid)activating.This means it is likely the starter motor is at fault.Two more tests to prove it.Next,using a jumper cable,connect one end to battery posative, touch starter motor posative terminal(by-passing solinoid).Did starter motor turn?It's likely it didn't.If it didn't you would suspect one of two things.One is a faulty starter motor-To test remove-bench test NOTE do this test with starter motor in a vice or on floor with foot on starter holding it down)-connect battery negative to body of starter motor-Battery posative touch to starter motor posative-Does it spin?(sometimes they will but with no torque).If it dosn't spin,sounds rough or seems weak then the starter motor has worn out brushes or is burnt out.Replace brushes or starter motor to repair. IF the starter motor bench tests fine- then the cause is a seized starter clutch or engine.To test if engine is seized up(unlikely)turn over with a wrench on the end of the crank(Engine LHS).
Hope this was helpfull
regards Andrew Porrelli
May 11, 2011 | 1995 Suzuki VS 800 Intruder
Wipers do not work in intermittent position. They do work in low and high speeds but do not automatically return to the park position. They stop wherever you turn the switch off.
i belive that your wiper switch has gone out on the intermittent side. this is a very common problem.
I hope this helps you
Thanks
Please leave rating
Apr 21, 2009 | 2000 Isuzu Amigo
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
