Question about Dryers
I have ADMIRAL CAPACITY PLUS HEACY DUTY 10.1 KG CAPACITY cloths dryer. It gives some cound into its machine and I need to greese it, but I can't find a place to put some oil on it. Could you please advice a way to put oil on its machine?
Krazytech
  • 725 Answers
SOURCE: I have an Admiral Designer
pull the pulley toward the motor the belt goes to the outside of the pulley... let me know
Posted on Jul 23, 2008
docjohn174
  • 943 Answers
SOURCE: Admiral Capacity Plus Dryer won't
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Posted on Sep 22, 2008
  • 1122 Answers
SOURCE: we want to purchase a
go to sears .com click on parts out in your model number and they should have what you need,or go to repair clinic .com and do the same-mike
Posted on Oct 27, 2008
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
svpsastry
  • 81 Answers
SOURCE: admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Posted on Jan 07, 2010
What is the capacity on a Admiral Mega22Plus heavy duty dryer?
The largest admiral dryer which has 27'' x 27'' dimensions is 7 cu ft.
Jan 15, 2017 | Admiral Dryers
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
I'm trying to install a 4-wire system electrical
Hi heathvaneato...
Go to the following webpage and you will see a picture and description of how to wire your dryer.
Please take time to rate me thumbs up.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.ph
Sep 23, 2011 | Admiral AED4475TQ
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
My Admiral Capacity Plus Clothes Washer Ends Cycle with a Squeal
my problem with my washing machine is that it take long to drain out the water.
Jul 13, 2009 | Washing Machines
Dryers Logo
57 people viewed this question
Top Dryers Experts
