Question about LG Heating & Cooling
I have an Lg LST244H-2 split system air con that does not blow air inside even though outdoor unit is running
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LST244H-2 Split system - Outdoor
Here is what is going on...
The unit has a leak in the refrigerant system...
The reason the outdoor fan will not come on is because it runs according to the pressures inside the system and so if you are down on charge then the system is not telling the fan to run...this is also why the unit is not heating properly...
Have a tech come, find and repair the leak, then vacuum and recharge the system correctly and you'll be heating again...
heatman101
Posted on Jul 13, 2011
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
One of my ductless a/c units is not blowing cold
Check to see if all of the outside condensing units are running. Identify the one that is part of the "problem" system. Is it running? What is different about that one than the others? Let us know and we will dig deeper into helping you troubleshoot.
If it is not running, check for any tripped circuit breakers or blown fuses to the outdoor unit.
Let us know.
I hope you find this information to be very helpful to you as a jumping off point, moving forward.
Please leave a rating. :-)
May 14, 2010 | LG LA185HV Split System Air Conditioner
Lg aircon not working, but no error msg.
Hi, From what you are telling me it is a ductless LG split system, with an indoor unit to blow air and the condenser will be outdoors on a pad. Sounds like it is getting voltage to the indoor unit, but when you set it to come on and you here this noise, it then stops. Is the noise coming from this indoor unit where the air comes out? Is it tripping the breaker to where you have to reset it, or do you turn it off after it stops? I think that you have a problem with the blower motor going out and it is trying to start, but fails to come on and blow air.This is something that I would not be able to have you check. It is a componant that requires a tech to come out and check. We have the tools for these units and if the motor is going out it would be very difficult for you to replace on you're own unless you know electrical and trouble-shooting.I hate to inform my clients to have to call out a tech, but in this kind of situation, you have no choice. Please keep me updated and if you can, go outside and locate the condenser.Turn the stat on and see if the outdoor unit runs. If it comes on, that is good. It would be the blower motor on the evaporator unit inside. Keep me updated, Sincerely,
Shastalaker7
Dec 20, 2009 | Microwave Ovens
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
Aug 25, 2009 | LG LS092CE Split System Air Conditioner
Hi i have a lg split system air con model number lst243h-2 its nice and cold when i first turn on then its just like the fan is on its not cold at all
How long before it goes from cold to hot. The compressor could be not running and going out on overload. The condeser fan could have failed. Did you check the outdoor unit. Is it running? Is the fan running on the outdoor unit. It could be low on charge which would cause ice. Are you getting excessive condensation? Let me know and i can help you out more. Grab the large copper line outside that is insulated and tell me if it is cold. It should be cold like a Pepsi out of the fridge!
Aug 23, 2009 | LG LSC183VMA Split System Air Conditioner
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
