Question about HP LJM1522-PCL6-netpnp-win32-ww.exe
I need hpLJM1522 PCL 6 drivers for printing and scanner specialy.
  • 46 Answers
Go to www.filehippo.com and enter the required driver. You will get freely install. Your problem will be easily solved.
Posted on May 29, 2011
Following a printing job of more than two or three pages, both orange lights and both green lights come on. The printer then is not functional. There is no paper jam. If I turn it off, then back on, it...
I had this problem at work. We went from a PCL 6 driver to a Universal PCL 5 driver and it worked fine printing multiple pages. And has ever since. I would check your driver first and see if it can be updated. If so, update it and try again. If not or updating doesn't work, try a different driver, especially if you are using a PCL 6 on a 32-bit or an XP machine. Best of luck to you.
Aug 04, 2011 | HP LaserJet 4L Printer
Printer goes offline after each print job
Go to manufacturer's website and download latest driver. Try Postscript (PS) and PCL 5e/6 versions.
May 24, 2011 | Computers & Internet
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
I need the printer driver for my Kyocera Printer, Laser type,FS 3800N.. How to get it and save it. Please advise. Bud
You can also go to www.kyoceramita.com.  Go to Downloads and USA, select your product "Legacy Printers" then your model.  Then select print drivers.  I would suggest the KX Driver.  It is the fullY Fuctional driver that has PCL 5, PCL XL(PCL 6) and KPDL(PS3) built in.  It also has some good add-ons like Print to PDF.  Hope this helps, I've been a Kyocera Tech for 11 years.
Feb 18, 2009 | Buffalo Technology LPV2-USB-TX1 Print...
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Pcl xl error , subsystem:kernel, Error: Illegal tag
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Jul 26, 2008 | HP LaserJet 1320n Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
Computers & Internet Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
