What is point and draw devices? - Computers & Internet
    Scholar:
  • 101 Answers
I believe you're referring to mice and tablets. tablets are devices that allow you to use a special pen to draw on them and the movements of the pen are transfered to the computer.
Posted on May 29, 2011
How to make a 5 point star
Use a compass to draw a circle the size you want your star to be.
Draw a second, smaller circle inside the first, using the same center point. Make the second circle about half the size of the first.
Draw a line from the edge of the outer circle to the center point using a ruler.
Place a protractor on the line, with the center hole of the protractor over the center point of the circle.
Measure and mark every 72 degrees around the circle (72, 144, 216, 288 and 360 degrees), dividing the circle into five even sections.
Line the ruler up with the center point of the circle and one of the marks you just made.
Draw a line from the edge of the outer circle, through the center point, ending at the edge of the inner circle.
Continue drawing lines as described until you have drawn the five lines, which evenly divide the circle.
Connect the top of one of the lines that touches the outer circle to the lines that touch the inner circle on both sides, forming a point.
Continue to connect the lines around the circle until you have made a five-point star.
  • Make the inner circle larger for a fatter star or smaller for a thinner star.
  • Draw your star on poster board and cut it out to use as a pattern for drawing more.
  • To make a six-point star, measure and mark every 60 degrees (60, 120, 180, 240, 300, and 360 degrees), dividing the circle into six even sections.
  • To make an eight-point star, measure and mark every 45 degrees (45, 90, 135, 180, 225, 270, 315, and 360 degrees), dividing the circle into eight even sections.
  • Quick and easy may want to do this a few times before the final perfect one. This actually made me think. Haven't done geometry in a very long time.
Dec 23, 2014 | Cars & Trucks
How do i use adobe illustrator?
Illustrator uses vector drawing tools, which require you to start with a range of points that are connected by lines... and contained areas are filled with color automatically as you draw. Look for the pen tool in the pallette, click points and watch them be joined by lines. To draw a curve, click and drag slightly before moving to the next point. This leaves a curve point, that has a set of handles you can manipulate. Good luck!
Oct 11, 2014 | Adobe Computers & Internet
My Tab will not start, I receive two different "draw failed" messages...if it is charging, it says, 'charging_7.jpg' draw failed. If the USB isn't plugged in the message is logo_expresso7.jpg draw fai
It sounds like the system image (operating software) got corupted and need to be re-installed. If you haven't got a backup image of your tablet, then you need to take it to a cell shop so they can re-install your OS (Operating System) software.
Mar 19, 2014 | Samsung - Galaxy Tab 2 7" 8gb Wifi
How to put a repeating decimal on a graph
You cannot. There is technique that can be used to locate a fraction on a line segment. It involves the drawing of parallel lines passing through equidistant points drawn on an intersecting line. The procedure is based on Thales' theorem.
Draw a real line (passing through 0 of course) Mark the limits of segment [0,1]
From the point 0 draw a line. Choose an arbitrary length measured by the opening of a compass. Starting from O, mark three equal segments along the second line. From the end of the 3rd segment draw a line that joins that end with the end of the point 1 on the real line.
From each of the two other points on the secant draw segments parallel to the one you just drew.
Here is how it looks on a picture.
If you have another fraction (5/7) draw 7 equal length segments on the second line (secant to the real axis). The parallel line from the 5th point will cut the real axis at the point 5/7
Dec 06, 2013 | The Learning Company Achieve! Math &...
Calculator is drawing vertical asymtotes.
There is no vertical (or otherwise) asymptote feature on a TI84PLUS. It seems to you that the calculator is drawing the asymptote. However when you plot a CONNECTED Graph a line is drawn from one point to the next: The last point on one side of the asymptote is thus connected to the first point on the other side, effectively mimicking the drawing of the asymptote.
To get rid of this spurious effect, draw dotted graphs, but you will see fewer points, because the points are drawn at constant intervals in X. This is set by the Xres variable, in the Window configuration screen.
Here is a function that will "show" you a vertical asymptote on the TI84PLus, when graph is drawn connected, but on a calculator with a higher resolution, you see none. A calculator cannot handle infinity. You can with the help of your mind's sight, so to speak, see the asymptote on the graph.
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
How do I turn off the vertical asymptote feature?
There is no vertical (or otherwise) asymptote feature on a TI84PLUS. It seems to you that the calculator is drawing the asymptote. However when you plot a CONNECTED Graph a line is drawn from one point to the next: The last point on one side of the asymptopte is thus connected to the fisrt point on the other side, effectively mimicking the drawing of the asymptote.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
Drawing problem in PS cs4
Go to your Brushes.
Click on the Brush Tip Shape tab.
Make sure the box is ticked that says 'Spacing' and set it as low as you can (1%) for the smoothest effect.
Aug 16, 2009 | Computers & Internet
My HP TX2050 pen works but the pen is not touching the screen.
you're probably resting your hand while you're writing...
this happend to me when i attempted to draw/write/what have you.
the computer can't differentiate between the pen tip and your hand, so what you need to do is disable your finger as a pointing device:
1) go to control panel
2) click on the mobile pc
3) go to pen and input devices
4) you should see a TOUCH tab. click on it.
5) uncheck the box that says "Use your finger as an input device."
This should help. obviously, you lose the capability to use your finger, and the whole idea of touchscreen in general, but you can always enable this after drawing or taking notes.
Hope this helps.
peace.
Jan 08, 2009 | HP Pavilion TX2000Z Notebook
Programs with variable number of arguments
To start points and lines are not shapes, and a triangle is not representable with a single function, therefore you need a function to draw shapes , given a number of points as parameters, and one to draw math functions (lines etc.).
Here is an example: Draw Line, Ellipse, Polygon ...
From website above, here is script in JS:
"<script type="text/javascript">
function myDrawFunction()
jg_doc.setColor("#00ff00"); // green
jg_doc.fillEllipse(100, 200, 100, 180); // co-ordinates related to the document
jg_doc.setColor("maroon");
jg_doc.drawPolyline(new Array(50, 10, 120), new Array(10, 50, 70));
jg_doc.paint(); // draws, in this case, directly into the document
jg.setColor("#ff0000"); // red
jg.drawLine(10, 113, 220, 55); // co-ordinates related to "myCanvas"
jg.setColor("#0000ff"); // blue
jg.fillRect(110, 120, 30, 60);
jg.paint();
jg2.setColor("#0000ff"); // blue
jg2.drawEllipse(10, 50, 30, 100);
jg2.drawRect(400, 10, 100, 50);
jg2.paint();
var jg_doc = new jsGraphics(); // draw directly into document
var jg = new jsGraphics("myCanvas");
var jg2 = new jsGraphics("anotherCanvas");
myDrawFunction();
</script>"
Oct 25, 2008 | Computers & Internet
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
