Question about LG Cell Phones
Problem with 2 G micro sd card for lg gm360. It's a red x on it, and cannot format and use. It's work on PC or other phone. Thanks.
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
SOURCE: v3i card formating
I got a solution for a 1gig card, so the 512mb max thing is nonsense.
Check this link: http://motox.info/showpost.php?p=333560&postcount=17
Register there, download the file and open with rar or zip. I formatted my card using the cardreader in my laptop (FAT, not FAT32) and added the files in the above file. Just place the "itunes" and "mobile" maps in the root of the card. Take it out, place it in your phone and voila!
note: works on a 1gig micro sd card. Don't know about 2 or more.
Posted on Dec 31, 2007
SOURCE: memory card micro sd cannot format
the card may be formated use window command prompt.
Posted on Apr 02, 2008
SOURCE: Problems with formating samsung e250 micro sd card
I had the same problem and I tried everything. I couldn't think of anything else to do so I just turned my phone off and back on again. When I went back to the memory card menu on my phone all the folders that I lost re-appeared. I don't know if it would work on other phones but it's worth a try!
Posted on Aug 26, 2009
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
Aug 22, 2011 | Gomadic Car Cup Holder for the LG T300 -...
Will not suport micro sd card how do i get that
Format the card in your phone and then it will be read by the phone. If it has any data on it the save the data to a PC and then format in the phone.
Jan 20, 2010 | LG Neon GT365 Cell Phone
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Jun 25, 2009 | LG KU990 Viewty
KS 360 won't recognize my micro SD card
best to back it up on your computer then FORMAT the sd card when inserted into your phone
Apr 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Micro SD card
try to format it using your computer.
Connect the card with computer using a card reader
Then go to my computer right-click the micro sd-card and select format. Format it using FAT.
May 24, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
352 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
