Question about Packard Bell Easy One Silver 2120 Notebook
IGo 5000 series - Cooling Fan start every 5-10 seconds
The cooling fan works continusly
even if the ambient temperature is not high (15° Celsius)
and even if I use 1 simple application (wordpad).
Please Help.
Regards
  • Packard Bell Master
  • 5,568 Answers
Most CPU fans are controlled by CPU temperatures and even when loafing, they get hot. When you DON'T hear them cycling, it is then time to worry.
Posted on Dec 15, 2008
Where is the cooling fan switch located on my 2005 malibu 3.5liter v6
Cooling fan switch ? The cooling fans (2) on that motor are controlled by three relays . A coolant temp. sensor gives temp info to the PCM - engine computer .
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan S/P relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The PCM commands Low Speed Fans on under the following conditions:
• Engine coolant temperature exceeds approximately 106°C (223°F).
• When A/C is requested and the ambient temperature is more than 50°C (122°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off if the engine coolant temperature at key-off is more than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans on under the following conditions:
• Engine coolant temperature reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set .
Watch this video ,it shows how it works !
Relay Driven Dual Cooling Fan Diagnostics
Nov 27, 2016 | 2005 Chevrolet Malibu
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
2004 Chevy Monte Carlo 3.4 the a/c stopped blowing,then it started overheating to the red within a couple miles,replaced the thermostat,the relay switch some days it overheats sometimes it runs fine
Are the cooling fans coming on ? What relay switch did you replace ?
The BCM will request low speed cooling fan operation from the PCM under the following conditions:
Engine coolant temperature exceeds approximately 103?°C (217?°F).
When A/C is requested and the ambient temperature is more than 10?°C (50?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is more than 117?°C (243?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the engine wiring harness junction block. The ground path is provided at G101.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the FAN CONT #1 relay coil, closes the relay contacts, and supplies battery positive voltage from the FAN CONT #1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the FAN CONT #2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the FAN CONT #1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the FAN CONT #2 relay and the FAN CONT #3 relay through the high speed cooling fan relay control circuit. This energizes the FAN CONT #2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the FAN CONT #3 relay coil is energized closing the relay contacts and provides battery positive voltage from the FAN CONT #2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Is your vehicles check engine light lit ?
Is the
Jul 10, 2015 | Cars & Trucks
Where is the radiator fan switch located on a 2002 oldsmobile intrigue
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G113. The relays are located in the underhood fuse / relay box .
So ,what's the problem Paul , car overheating ? Fans not working ?
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the cooling fan 2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan 3 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the cooling fan 3 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Engine coolant temperature exceeds approximately 106?°C (223?°F).
When the A/C is requested and the ambient temperature is more than 50?°C (122?°F).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1655 kPa (240 psi).
When certain DTCs set.
So
May 11, 2015 | Oldsmobile Cars & Trucks
I have a samsung rt58eamt. The temperature in the fridge is running high. It is not cold anymore. I checked the fan and it is working.
If the temperature is going above 10 degrees Celsius, or 50 Farenheit then your thermostat or the cooling aggregate will be defect. You need more than a fan to cool. ask a technician to look what is wrong, or if it is an old one, start saving for a new one.
Jun 23, 2014 | Refrigerators
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
Projector heating up and bulb shuts down
get a small fan and place it near the projector to provide
Jul 08, 2010 | Dell 2300MP Multimedia Projector
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
Code p1652 on a 1996 pontiac grand prix does anyone know what it means the book for computer codes is incomplete
Trouble code P1652 means: Cooling Fan 2 Relay Control Circuit Malfunction
I would start by checking power supply to the cooling fans,making sure the coolant system is full,& using a scn tool to verify the proper operation of the cooling fan system.Here is some info to help you.
The Powertrain Control Module (PCM) controls the operation of the cooling fans. This is accomplished by providing a ground path for the cooling fan relay coils within the PCM. The relay contacts will close and complete the circuit between the fusible link at the battery junction block and the fan motors. Whenever there is a fan ON request both fans will be running.
Power for the fan motors is supplied through a fusible link at the battery junction block. Battery positive voltage is applied to the cooling fan relay contacts and coils. The cooling fan relays are energized when current flows through the relay coils to ground at the PCM. The cooling fan relay #1 control circuit is used for low speed cooling fan operation. The cooling fan relay #1 control circuit and the cooling fan relay #2 and #3 control circuit are both grounded for high speed fan operation. The cooling fan relay control circuits are monitored by the PCM. Before using the Electric Cooling Fans diagnostic tables be sure to perform the Powertrain On-Board Diagnostic System Check. If diagnostic trouble codes P1651 or P1652 are present, use the appropriate DTC diagnostic tables prior to performing Electric Cooling Fans diagnostics.
Important:
When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. It is important to perform the Powertrain On-Board Diagnostic System check prior to diagnosing the engine cooling fans.The PCM will complete the ground path for cooling fan relay #1 under any of the following conditions:
- When engine coolant temperature exceeds 105°C (221°F)
- When A/C is requested and ambient temperature is greater than 10°C (50°F)
- When A/C refrigerant pressure is greater than 190 psi (2 volts)
For high speed cooling fans operation, the PCM will delay control of the cooling fan #2 and #3 relays for 6 seconds. The 6 second delay ensures that the cooling fan electrical load will not exceed the capacity of the system. The PCM will complete the ground paths for cooling fan relays #1, #2, and #3 under any of the following conditions:
- When engine coolant temperature exceeds 113°C (235°F)
- When A/C refrigerant pressure is greater than 275 psi (2.9 volts)
If a problem that involves the low speed cooling fan relay control circuit (cooling fan relay #1 control) exists, DTC P1651 should set. If the problem affects the high speed cooling fan relay control circuit (cooling fan relay #2 and #3 control), DTC P1652 should set. A problem with the ECT sensor should set DTC P0117, P0118, P1114, or P1115. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis table. The Electric Cooling Fan Diagnosis table should be used to diagnose the PCM controlled cooling fans only if no DTC is set.
Hope this help to solve your poblem (remember rated and comment this help).
Mar 21, 2010 | 1996 Pontiac Grand Prix
Van chevrolet venture 2000
Fifteen minutes! you have bigger problems than only the fans the fans are controlled by a thermo switch that is heated by the coolant, If you have no coolant the sensor cannot activate But fifteen minutes seems like you may have a headgasket problem and steam cannot heat the coolant sensor.OperationNotesThe electric cooling fan operates when the engine cooling temperature exceeds a certain value. The cooling fan on this engine is controlled by the Powertrain Control Module (PCM) . The PCM turns the cooling fan ON by grounding the coil of the cooling fan relays when certain conditions are met. When the A/C is requested, the cooling fan will also be turned ON.
Power for the cooling fan motors are supplied through Maxifuses(R). The cooling fan relays are energized when current flows from the fuses in the Underhood Accessory Wiring Junction Block, and through the relay coils to ground through the PCM. The Coolant Fan 1 Relay Control Circuit is grounded for low speed fans operation. During low speed fans operation, both fans run at a slow speed. The Coolant Fan 1 Relay Control Circuit is grounded for high speed operation. During high speed fans operation, both fans run at high speed.
IMPORTANT: When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. Perform the A Powertrain On Board Diagnostic (OBD) System Check prior to diagnosing the engine cooling fans.
For more information regarding the Charging System, refer to Charging System Description , and Charging System Circuit Description in Starting and Charging.
If a problem that involves the low speed cooling fan relay control circuit exists, DTC P0480 Cooling Fan Relay 1 Control Circuit should set. If the problem affects the high speed cooling fan relay control circuit, DTC P0481 Cooling Fan Relay 2 Control Circuit should set. A problem with the ECT sensor should set DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage, DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage, DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage, DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis.
For more information regarding the Cooling System refer to Engine Cooling Fan Description - Electric, and Cooling System Description in Cooling System.
Here is the electrical schematic and how it all is suppose to work,
If you need any further help please contact me Thank you,Randy If you find this information helpful please give me a good rating
www.aceautomotive1.com
Aug 16, 2008 | 2000 Chevrolet Venture
Packard Bell Easy One Silver 2120 Notebook Logo
93 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
