Question about LG 26LX2R 26 in. HD-Ready LCD TV
Hallo, Onday power supply was out,that time TV also switched off.From next day my TV is not working.The power indicator not giving light.What is the problem?.Where I can give the TV for repair?Where is the LG service centre in TVM or Kollam(dist) at Kerala?
  • 517 Answers
Good day!Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
I hope this solution will be helpful.Thank you and good luck.
Posted on May 29, 2011
Sony lcd tv model kdl-46EX711 one hour work good after stop start but no start red light [7] time blik next day start one hour why whats rong?
HI,
Probably the power supply have some faults. Mainly due to the dry filter capacitors. if you can replace the electrolytic capacitors in power supply board. Hope it will workout.
http://electro-medical.blogspot.in/
Apr 29, 2015 | Sony Televison & Video
TC-P42C2 Power Indicator Light Flashes 7 times, No video or audio
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Panasonic TCP42C2 42 in TV
I am watching my 14 days old JVC 21"TV but
Hello
Your TVs power supply regulator section has got some trouble with it, that is why power indicator doesn't light up. You have purchased it only fourteen days back, surely there will be warranty for it. Do not open the TV. The company will give no concession if the set is opened. Send it to the authorised service center and get it repaired. Some power supply faults may fatal, and may have to spend more. Since your TV is a new model, spare part availability in the open market may be difficult. Send it to them and let them do the work. OK.
Nov 09, 2010 | JVC AV-A21M3U 21" TV
Hallo. I have a Prosonic TV type LC-27M65 that will not switch on. The red control light for remote is on. The yellow light indicator for current is off. Although TV is connected to net for power, the...
It is possible that your TV has encountered a fault in the power section possible a short in the drive power section. hence on powering the power sully working OK is switching the secondary power to the main board but this short is taking in more current than specified. the feedback of this is read by the SM unit to shut off the power to protect the supply. Hence you will have to probe into the sections to find this short, perhaps a HT drive transistor or the HT transformer or capacitors. If will be easier to check the continuity with a meter. Please attemptt only if familiar otherwise take help. Disconnection of the shorting section will switch the power, replace teh component in question. Hope you try. Good day
Aug 16, 2010 | Prosonic Televison & Video
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
Sir after changing the battery ups worked well one day and the next day onwards when i pressed the switch red and amber lights blinking and the upc trips with beep sound .kindly give the solution
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
The true UPS types are usually the higher KVA units (over 1500 VA) that supplies uninterrupted mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power therefore there is no switch over time lag from the mains to the battery.
Oct 16, 2009 | APC Computers & Internet
JVC TV Sleeping
Indicates a power supply failure, needs a few filters replaced expect to pay $100-150 Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | JVC AV-27320 27" TV
Gestetner 3245 No light on screen after switch on. What has Failed?
can have some defective solder in the power supply.
Check the power supply board solder.
Oct 28, 2008 | Gestetner DSm645 Digital Imaging System
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No sound or picture, just a blinking light
The next time it goes out, count the flashes that the timer light does and thats an indicator of what is failing. Here is a chart of said flashes and there codes.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32HS510 32" TV
LG 26LX2R 26 in. HD-Ready LCD TV Logo
275 people viewed this question
Computer Repairing
Computer Repairing
