Question about Cannon i70 Printer
Normally used the printer with my laptop, trying to print off my desktop, does not recognize it, can't find the disk to download installation
    Scholar:
  • 101 Answers
You can download the driver from Canon's website here : http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i70#DriversAndSoftware Just select your operating system and language then click 'drivers' to expand the menu be sure to unplug the printer from your desktop before installing the drivers, plug it in after its done, or when prompted by the driver install.
Posted on May 29, 2011
I have a new laptop computer. It will recognize my epson nx100 printer, but it won't print.
Install Epson printer software from Disk if not disk then go to Epson website and locate your printer and download.
Mar 19, 2014 | Epson Stylus NX100 InkJet Printer
How do i connect an hp officejet printer to a wireless laptop
Download and install the drivers & software necessary for your printer from HP's website (www.hp.com) on your laptop. After the software and/or drivers are installed, connect the printer to the laptop with a usb cable. As long as the software is installed the pc should recognize the printer as soon as the usb cable is connected. Then just print as normal.
Oct 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Need to connect my printer kodak esp-3 to my laptop using a usb cord
Install the software for your printer on your laptop. Then connect the usb cable to the printer and the pc will recognize it. Then just print as normal. The pc will not recognize the printer until the software has been installed. If you have lost your driver disk, you can download a free copy from Kodak's website.
Oct 25, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have the lexmark X63 printer and I need to use it. I need to print something and I do not have the cd to get the driver. My lexmark 2500 has stopped on me so I was trying to use this one I had before I...
Depending on the age difference between your operating system and the printer, you may get some functionality by doing this:
Power down your computer system and then connect the printer. Make sure the printer has power and is turned on.
Restart your computer.
Windows may recognize it and install the appropriate driver. Watch the lower right-hand area of your monitor during the boot. If Windows sees it at all, it will open a message box and either tell you it is installing the driver or it will tell you to insert the disk that came with it (which you don't have.)
Going to the Lexmark website, you should find downloadable installation packages for virtually any printer they ever built.
You might create a new folder prior to trying to download and give that folder as the destination for the download. Normally, you will be able to start the installation procedure from within that folder.
Sep 11, 2011 | Lexmark X63 InkJet Printer
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
I have a new MacBook Pro and cannot get my Brother printer to work with it. The computer recognizes the printer but does not print.
Did you install the Mac driver for MFC? The MFC comes with driver for windows and Mac. Place the Mac Driver disk to DVD slot and run the installation for your MFC printer. Follow the instruction to complete the installation.
When you try to print something, make sure the MFC printer is selected.
If you've done all of this and still not able to print, please turn off your MFC, wait 15 seconds and turn on again to see problem solve or not.
Hope this will help. Thanks for reading.
Jul 19, 2011 | Brother MFC 420CN All-In-One InkJet...
I had my printer connected to my laptop once, but now its on my desktop computer. When I was scanning some papers after a while, I accidentaly clicked to scan to my laptop instead of my desktop, so now it...
Go to start>control panel >programs and features>uninstall the printer>Then use your install disk and reinstall the software without being connected to your printer.When the install disk tells you to hook up your printer do so.If this doesn't work why not just print to your laptop and and just start over when it's done?
May 07, 2011 | Lexmark X6570 InkJet Printer
I want to install printer in my laptop without cd
husen39,
You can install a printer without the cd.
First connect the printer to the USB port if that is how it hooks up, this is the most common hookup. Power the printer on. Give the computer, which should already be running, some time to recognize the printer. It will ask for the disk (cd) or if you want to browse for it. Cancel the setup at this time.
Google your printers brand. Go to the company web site. You should see a link to 'drivers and downloads' click on this. A page will open usually with a search engine. Input your model. You should be presented with software for your model printer to download. Follow the instructions and download the software to your desktop.
When done close the internet and click on the software you just downloaded. It should start an install. Follow the instructions and install the software. Reboot your computer and go to the printer setup. Find your printer and open the maintenance menu. You should be able to do a test print at this point. If your printer prints a test page you are done.
I would save the downloaded software to a file which you can easily recognize and burn it on a cd.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 11, 2010 | Office Equipment & Supplies
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
