When pressing Menu on Scan only two option come up. There use to be several opition to come up.
  • 3 more comments
  • djhill50 May 29, 2011
    HP Officejet Pro L7680 All-in-One.
  • djhill50 May 31, 2011
    I still have only 2 options on the scan menu
    I still have only 2 options on scan menu. after trying the 8 steps.
    After trying the 8 steps, I still have only 2 options on the scan menu
  • djhill50 Jun 03, 2011
    I am still having a problems with trying to scan. There are only 2 options appears on the menu bar.
  • 3,530 Answers
Welcome to Fixya
This may lead to hardware or firmware problem. May i know the exact brand and model of the printer. This will help me identify what's causing the problem.
Your response will be highly appreciated.
Thank you for using Fixya!
Posted on May 29, 2011
  • Jose Cada
    Jose Cada May 29, 2011
    Try to reset the printer first to factory default state. Please see procedure below:
    1 Take out the cartridges from the unit .
    2 Make sure the unit is connected to the wall jack directly without any surge protector.
    3 Unplug the power cord from the back of the unit ( without turning off the unit ) .
    4 Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
    5 Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
    6 after one minute turn on the prnter . it will go into alligment phase > let it finish .
    7 Allow the all-in-one to re-initialize. This may take a minute or two.
    8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
    NOTE - in case the issue is with top feeder then use the ok and cancel key combination
  • Jose Cada
    Jose Cada Jun 01, 2011
    if that is the case then you might need to contact HP and have the firmware reconfigured to the printer.
Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
Jan 05, 2013 | Televison & Video
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I cant find my contacts they are hidden show me how to find them
Hi, If the contact file is hidden, you need to press the menu button and again press the menu button you will be able to find the opition Hide, Show All etc... Select Show All to view the all the folders. I Hope it will help you. Thank you for using ' Fixya ' and have a nice day!!
Oct 08, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
How do i scan and email a document using the a940 printer
On the printer press scan, then press options, move the right arrow key. Select e-mail and press select button. Also, go to start menu, go to all programs, Dell printer, then select DELL AIO Printer A940, then select Dell All-In-One Center. On the Scan box on the drop menu select e-mail. All set, scan from printer to e-mail.
Sep 25, 2009 | Dell A940 All-In-One InkJet Printer
OSD Menu on my montior is lock on a Balance CM2017 LCD monitor i cant change any of my menu opitions....HELP
The answer depends on your monitor model, of course.
For some of the LCD models you may reset the monitor by pressing (and releasing) the "MENU" button (OSD menu appears) then hold the "SOURCE" button for a few seconds. When you see the monitor blinks it means that reset was done.
Apr 20, 2009 | Computers & Internet
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Reset code for Waste Ink Full on a Canon MP750.Have cleaned the pads but still need the code. Help please
Service Menu
Press MENU-SCAN-COPY-SCAN
Cycle through options to #7 PRINTER, Press OK
Cycle through options to #5 (Ink Abs Cap) Press OK
It should say "SUCTION" on the screen. Enter "0" (Zero). Now either press OK or vack out of the menu altogether.
Turn printer off and then back on.
Jul 17, 2008 | Office Equipment & Supplies
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
I'm trying to scan a picture and save it to my computer. I read the directions, it says to press scan menu.Then press scan to computer but, when I press scan menu it just has 2 options. Scan and reprint...
me too. What I just did, was open up word and then pressed scan. That worked, so maybe open the place you want the scanned item to go to and it will go there. You can tell I'm not a techie.
Apr 08, 2008 | Office Equipment & Supplies
16 people viewed this question
k24674
