Question about Samsung Galaxy Tab Tablet PC
My samsung tab is not booting up. i was using it fine untill now. It was low on battery and got off as battery got exhousted. Now its not charging
  • EJ Kudelka
    EJ Kudelka May 29, 2011
    You are using the original charging cable correct? Try to charge it using your computer too. Let me know if it charges using the computer or using the wall charger.
    Thanks!
    EJ Kudelka
  • 34 Answers
Charge wth ur tab charger
dont charge with usb
Posted on May 30, 2011
Why does the Battery Drop so fast On Samsung tablets
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Jun 23, 2017 | Samsung Tablets & eReaders
My galaxy tab A keeps booting on start up like it keeps showing Samsung and keeps repeating? How do I fix it?
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
Nov 04, 2016 | Samsung Tablets & eReaders
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
Galaxy tab 2 10.1 does'nt show thw level ef charge
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Mar 26, 2014 | Samsung Tablets & eReaders
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
Samsung galaxy tab 2 10.1 brought today and charging through computer keeps flashing a battery but then disappearing and making a disconnected sound from computer what do i do?
Samsung galaxy is a powerful device which require at least a 2A charger to charge it well. computer can only deliver 0.5A and thus is not enough power to charge your tablet. Connect it to the wall AC charger that come with the tablet and you'll be able to charge it just fine
Sep 16, 2013 | Samsung Galaxy Tab 2
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Samsung battery wont charge need to reset it
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 15, 2013 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab Tablet PC Logo
552 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
