Question about MSI K9MM-V Motherboard
Hi im using ms-7312 ver.1.0 motherboard newly formatted by sound is not coming pls help me
  • MSI Master
  • 32,281 Answers
You can download the audio and device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Posted on May 29, 2011
  • MSI Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
I want THE Driver of MS:7312 VER:1.0 VIA Mother
Do you mean the VIA chipset drivers or the entire Motherboard drivers? Audio, Sound, chipset, etc....
Jan 03, 2010 | AMD Computers & Internet
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
Ms-7142 ver:1 audio driver i want a free download
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
Brian
Aug 04, 2008 | MSI K8MM-V Motherboard
Problem with audio driver
haii,
Im using ms 7173 ver 1 motherboard and via chipset VT8237R and AMD sempronprocessor. I have problm with my audio driver so pls help me for downloading the corresponding driver.
Thanks
Sajeesh
Jul 08, 2008 | MSI K8MM-V Motherboard
Audio driver ms7142
I'M IN NEED OF SOUND DRIVER AND VIDEO DRIVER OF THE MS-7142 VER:1 MOTHER BOARD
Jul 07, 2008 | MSI K8MM-V Motherboard
MSI K9MM-V Motherboard Logo
100 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
