Question about Linksys Wireless-G WRT54G Router
I have 3 computers, 2 laptop's and one desktop. I'm trying to secure my wireless router, which is connected to a voip router and speedtouck internet
  • 2,794 Answers
Go into the admin of your router. By default it should be http://192.168.0.1
user id: admin
password: linksys
select wireless.
I use 64 bit wep encryption because I have cell phones and pdas that can use basic wep encryption. If you have other appliances in your house running wireless 128 bit encryption may not work on those devices.
You can create a phrase. It will generate a 4 keys for you based on the passphase given. It defaults to the first one. You might want to print the screen out. Save it to your router.
Rescan the network on your routers. You will be prompted to insert the key. Use the key 1 settings and save it.
Posted on Aug 16, 2008
SOURCE:
I have 2 computers - a desktop without wireless and a new laptop with wireless. I want to connect the Belkin N150 basic wireless router to both these computers. I have introduced a "wired"...
WIRELESS SECURITY ISSUES
UNINSTALL THE BELKIN ROUTER MANAGER FROM THE LAPTOP
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP ( WPA WILL NOT WORK )
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin Basic Wireless Router
I bought this US Robotics wireless (model 5461 (Maxg)) maybe 3 years ago. I haven't used it in maybe 2 years and now it wouldn't work anymore. I recently switched apartments and computer, it used to work...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 04, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
I could see my SSID, full signal but could not connect
I think the best thing to do is to get in touch with your VOIP provider, as they will likely provide you with free customer service on this issue, AND they are able to remote into the product, and show you the correct configuration and method for setting it.
Hope this helps!!
Jim
Aug 06, 2009 | NetGear WGR614 Wireless Router
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Belkin wireless 'N' with Vonage router and cable ISP modem...
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Nov 07, 2017 | Belkin (F5D8231-4) Wireless Router...
Problem with connection of networking and VOIP.
Go to your Run program on the computer that your are having connection problems with. Type cmd.exe in the box. When your DOS page appears, type in ipconfig/ release. Be sure to use a space between the / and the word release. After it releases, type in ipconfig/ renew, using the space as well. Close out of your DOS. Recheck your internet connection. Before you recheck it though, make sure that your computer's wireless password, if you are using any, are the same as your wireless router's password. Hope this helps.
Sep 07, 2008 | Compaq Presario Notebook
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Aug 03, 2008 | NetGear : WGT624 108 Mbps Wireless...
Lose Connections over and over...
You may need to set specific ports on your router to use the voip. log onto router and go to the applications and gaming tab to set the specific ports voip needs to access Internet.
Jul 07, 2008 | Linksys Wireless-G WRT54G Router
Internet connection
hello!
1. what is the model number of your wireless adapter?
2. what is the operating system of your computer?
3. how far is the laptop from the router?
-- try to change channel on the router
-- try enabling wireless security on the router and on the wireless adapter
-- diable other 3rd party firewall on your laptop
Apr 14, 2008 | D-Link DI-634M Wireless Router (DI634M)
Linksys Wireless-G WRT54G Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
