Question about Marsh Allan 86851 Grill
HELLO. THIS IS MY FIRST TIME GRILLING ON MY OWN. MY QUESTION IS BY THIS GRILL NOT HAVING A LID WHAT IS THE BEST WAY TO COOK W/O HAVING TOO MUCH SMOKE. B/C I SATY IN AN APARTMENT COMPLEX IM CONCERNED ABOUT COOKING W/O A LID ON THE PATIO. SHOULD I BE CONCERNED.
  • 3,053 Answers
The best way to cook on a BQ and have min smoke is to put tin foil on the grill with only a couple holes punched it for fat to drain, and don't let flames flair up, use water botttle near by to squirt coals if flames appear and spray some to put out flame. What causes smoke is the fat and juices from the meats hitting flames, this method cuts 90 percent of that.
Posted on May 29, 2011
I need a new knob for a Captain Cook grill by Barbeque Galore model XG4CKW
If BBQ's Galore hasn't been able to help you, try the link below. They should be able to help you.
http://www.appliancefactoryparts.com/gasgrillparts/brands/barbeques-galore/barbeques-galore-knobs.html
Good luck & Happy Grilling!! Thanks for choosing FixYa.
Aug 09, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
The users manual arrived with the product but there are no user instructions and aswell as direct grilling I want to use the grill to cook joints etc. What setting do you use for indirect grilling and Is...
Direct Grilling is putting the items you're grilling directly over the burner(s) . Indirect Grilling is preheating the grill, turning off one or two burners and place the food over the burners that are OFF. In direct grilling requires cooking with the lid closed.
For more info on using a gas grill, as well as recipes got to the following link.
http://www.barbecuen.com/begin-gs.htm#axzz1SkGNJ9p8
Happy Grilling!!
Jul 21, 2011 | Ducane Affinity 3100
Will not get hotter than 250F
Temperatures on the Big Green Egg are controlled by opening or partially closing, the dampers on the bottom side of the grill and the top of the grill lid. The more open, the more air gets to the coals and heats the up. Partially closing the dampers lowers the temp.
Keep in mind, the grill thermometer may be faulty. Try setting an oven thermometer (like the kind used in a regular kitchen oven, that sits on the oven rack) on top if the grill grates, when you're preheating the grill with the lid closed.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!
Jul 04, 2011 | Big Green Egg Grilling
With the lid closed the grill gets up to 700 degrees. How can I regulate it down?
The control knob on the right side of the grill, below ignitor button, is what you use to control the flame height, as well as the temperature. Opening the valve raises the flame in infinite amounts. Lowering the flame, after the grill has preheated with the lid closed, will give you better control over what you're grilling.
To be quite honest, I wasn't familiar with this grill. So, I did a little research. It's gotten rave reviews from the RV crowd and really looks like (once you get the hang of it) a great grilling experience.
Hope this helped you and Happy Grilling.
Jun 28, 2011 | Camco Olympian 5500 Stainless Steel...
No problem, how do you grill an italian sausage, **** before grilling or after turning
Italian Sausage is fun to grill.Bring the sausage up to room temperature before grilling. That way they will cook evenly. Preheat your grill to medium heat (350 is fine). Place the sausage links on the grill and cook slowly. Turn the links frequently, so that all sides get that light crispy outer texture and cook evenly. Never ever use a fork to move or turn the sausage links. Always use tongs. You don't want to pierce the meat and loose all those tasty juices. Depending on how many you're cooking, 15 to 20 minutes is usually enough. Remove one from the grill and test it for donness, by slicing it in half with a knife. If the inside is still pink, give them 5 more minutes. If it's not, remove the sausages and enjoy!
I like ,with sauteed onions and lots of Plockman's Mustard.
Apr 01, 2011 | Weber Genesis Silver B Grill
Hello, we have a 3 switch stainless grill that has NEVER heated up properly. It always seems to stay luke-warm. Please help.
First, how high are the flames when turned to high as opposed to the low setting on each of the 3 burners? If there's no significant difference in height between the two settings, here's what I want you to do.
Turn off the gas tank (that's assuming you are using a 20lb LPG cylinder) and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the Tank Valve ON very, very slowly, until it's fully open. Now, light each burner individually turning them to high. Are the burner flames higher than before? If so, you just solved your problem.
Remember to turn the tank ON very, very slowly after turning it off to change the tank or if you turn the tank off after each time you grill. Also, when grilling preheat the grill with the lid closed, after lighting the burners.
Hope that solved your problem ... Happy Grilling!
Feb 15, 2011 | Ducane Rottisserie 2004 (LP) All-in-One...
Need instructions for George Foreman Grilling Machine Model @ GR26CB
Hello there
Here is 2 links that have the manuals on it below this post ok?
i hope that this is very helpful for you
Best regards michael
George Foreman Electric Grill Model Number: GR26CB | ManualsOnline George Foreman OWNER'S MANUAL Grilling Machine GR26CB, GR26BLK, GR26CBRD ...
george forman model gr36vt manula. owners manual operating instructions recipes
... http://kitchen.manualsonline.com/manuals/mfg/george_foreman/... - 63k - Similar pages Free George Foreman Kitchen Grill owners manuals, user guides ... GRV160S; GRV80 - GEORGE FOREMAN Fat Grilling Machine OWNER'S MANUAL GRV80; GV12
- GEORGE FOREMAN ELECTRIC GRILL OWNER'S MANUAL Model No. GV12 ... http://kitchen.manualsonline.com/manuals/mfg/george_foreman/... - 68k - Similar pages
Nov 16, 2009 | George Foreman Kitchen Appliances - Others
Coal starts dying out the moment I put the Grill
even with all the vents open the air is restricted with the top on. This is what makes the kettle such a remarkable cooking machine. If you wish to grill then leave the lid off and cook directly over the coals, if you are grilling a thicker cut of meat such as a 1 1/2" thick porterhouse you might want to put the lid on for a while to more or less bake or broil the meat without blackening the surface of the meat and to achieve the desired internal doneness of the cut. you can also stack your briquettes/lump to one side and put the lid on so the exhaust is opposite to create a non direct cooking environment for cuts such as butts, ribs, briskets, whole chickens etc
Sep 12, 2009 | Weber One Touch Silver Charcoal Grill
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
Unsatisfactory grilling
You need a bigger, more powerful grill. It sounds like the one you have cannot keep up with the amount of food you want to cook. Other than making sure any controls are set on maximum, there's not much you can do about this. Return the unit for a refund.
Apr 11, 2007 | DeLonghi Perfecto BG24 Indoor Grill
Marsh Allan 86851 Grill Logo
60 people viewed this question
Top Marsh Allan Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Marsh Allan Grilling Expert? Answer questions, earn points and help others
