Question about Kelvinator Refrigerators
We have a kelvinator opal n520 and water is pooling in the bottom of the fridge under the vegetable crispers and water leaks out onto the floor
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: kelvinator frost free fridge leaking, pooling
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Jan 06, 2010
Testimonial: "Thankyou so much for such a quick reply to an Australian, can't ask for better service! I will try your suggestions which make perfect sense."
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
N520 fridge is leaking water onto the floor
Clean the drain situated at back (inside) of fridge cabinet (not the freezer). Use a piece of expanding wire about 1 meter long to get around the 90degree bend and into the water tray sitting on top of
compressor.
This pipe often gets blocked with food particles.
If problem persists it is usually the defrost cycle being too long and in this case the defrost cut-off sensor will need to be replaced .
Feb 19, 2014 | Kelvinator Refrigerators
My kelvinator opal N520 is leaking water at the bottom under vegie trays?
If your refrigertor is an auto defrost model, the drain tube may be clogged.
Dec 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
Water leaking onto the floor and down the back of refrigerator to the bottom under the vegetable crispers?
You have a problem with the auto defrost drain system.Carefully take off the cover by the light and control and see if you can clean out the drain. Sometimes you can get to it from behind the refrig. but that means you have to move the refrig out from the wall.Hope you find this helpful.
Jun 12, 2011 | Whirlpool Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water leaking and collecting at the bottom of the fridge under the vegetable crisper
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
I have a new F&P refrigerator model E450RXFD upright fridge only, I have only just got it last week... I have water pooling on the bottom under the fruit and vegetable crisper part ???? any ideas what...
I have the same problem with my E450RXFD, 1st week i got it and noticed it pools water under the crisper. Not too sure what to do about it.
My parents have the same fridge (only 8 years old and theirs does not pool water)
Dec 26, 2010 | Fisher and Paykel Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
117 people viewed this question
Top Kelvinator Refrigerators Experts
John Tripp
John Tripp
billconfused
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
