Question about Polaroid TLA-04011C 40 in. LCD TV
I plug in my tv with a 125v cable my tv and nothing happens.
  • 517 Answers
Good day!Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
I hope this solution will be helpful.Thank you and good luck.
Posted on May 29, 2011
What power cord can I use for my TV?
Not 100% sure but I have swapped cables from pc, tv, and monitor freely between them all to get right length of cable for each device and I have had no problem with any of them.
If you want to be safe start with the lowest power out put cable and work up, that said have just checked several that I am not using and they all appear to be the same output
Mar 04, 2016 | Televison & Video
What happened and what can I do.
You can remove the hard drive from your computer and hook it up to another computer using an adapter that plugs into the USB port of the other computer. I will share a link to Amazon, the are very inexpensive. Amazon com Sabrent USB DSC9 USB 3 0 TO SATA IDE 2 5 3 5 5 25 Inch Hard...
Apr 16, 2017 | Computers & Internet
My Sharp Flat Screen Tv Model LC32SB24U has a USB input recepticle in the back. I bought a usb cable connected it to my computer and nothing happens? what is it used for. My tV came with NO disc for...
The USB entry is mostly used for a foto slide show.
Please read the owners manual before plugging in any kind of USB sticks or other cable's in a TV set.
It can damage the set when there is a ground connection between some devices.
Nov 12, 2009 | Sharp LC-32SB24U 32 in. LCD TV
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Sylvania edtv ld200sl8
will not power. the fuse 4a 125v blows immediately when plugged in.
Sep 04, 2008 | Sylvania Televison & Video
Xbox 360 component cable resolution problems with tv
you can only play hd when you have all six plugs in not just the normal 3... i had this problem too
Jan 08, 2008 | Mitsubishi WD-73734 73" Television
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
T.v won't turn on at all
The 6.3 Amp 125V fuse always blows on this TV after a while. replace with a 6.3Amp 250V fuse and it should do the trick unless something else is wrong. a 6.3 amp 125V is almost impossible to find so chances are if you find a 6.3 it will work. Tried a 6 Amp 125v at first and it blows after the first time you turn it on and off and then back on again. 250V seems to work well. Hope this works for anyone else with this TV. Beats having to move it to the trash because it is HEAVY.
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Polaroid TLA-04011C 40 in. LCD TV Logo
109 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
