My Samsung sync master 793DF color is changed to green how can i fix it
    Scholar:
  • 101 Answers
Unfortunately this is an aging problem with the older CRT monitors, they will often do it for short periods at first, then remain that way permanently. There is an outside chance it is being caused by a bent pin, unplug the data cable and have a look at it to make sure all the pins are standing properly upright, but most likely the monitor will have to be replaced.
Posted on May 29, 2011
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
I have samsun syncmaster 519s 15'' crt monitor, its not properly showing colour, its showing green vertically and horz... and other problem is every 2 or 3 minute after showing black screen if I touch body...
most likely one of the color guns has burned out. this monitor and in fact all CRT monitors are obsolete and only worth 5 to 10 dollars in good condition, Its time to break down and buy a new monitor as it is not worth fixing. sorry to say, but true
Mar 16, 2011 | Samsung 793DF 17" CRT Monitor
My syncmaster 591s monitor is showing only green colour
Your picture tube has a problem already, when it goes green. Maybe you can try resetting all the settings to default, when you do so and it doesn't get better then its time to change it.
Mar 14, 2011 | Samsung 793DF 17" CRT Monitor
I cannot adjust brightness 0n my sync master 710v mniter. Described as auto adjust locked.
Click start control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range
hope this helps
Jan 31, 2011 | Samsung Computers & Internet
It takes nearly 10 sec to check my monitor post
Boot your PC, and in your BIOS setting, enable Quick Boot.
Feb 18, 2009 | Samsung 793DF 17" CRT Monitor
My monitor didnt work at all the green led too
changing the powersystem on the monitor board fix it
Feb 13, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Hi, my monitor is "Samsung SyncMaster 793df". Problem is i can't set right color and contract. how can i solve it?
If the monitor has a consistent tint throughout, try to adjust the color through the OSD (On Screen Display). If this does not resolve the problem, or your monitor seems to be missing a color, disconnect the signal cable from your computer and wait for the No Signal image to appear. If all colors - red, green and blue - are present in the No Signal image, the problem is not with the monitor, but possibly with the video cable or video card. - exert from samsung faq....
http://ars.samsung.com/customer/ctry/jsp/faqs/faqs_view.jsp?isINPUT=Y&SITE_ID=58&PG_ID=-1&AT_ID=48749&PROD_SUB_ID=0&PROD_ID=28
If you mean something else, go into a little more detail if you wouldn't mind... Also, another thought has popped to my mind, you do have the drivers for your monitor installed?
Jan 13, 2009 | Computers & Internet
Color of the monitor is in problem
I don't know why samsung company didn't do anything about this problem. It will cost their business to downgrade. Most of my monitors have the same problem like this. Even the service center can't do anything about this problem. So I recomend to those who is planning to buy a good monitor not to buy samsung monitor or else, you will experience the same problem as mine. Well if samsung personnel can read this, pls. give us advise how to solve this problem or else you will lose most of your customes.
Nov 28, 2008 | Samsung 793DF 17" CRT Monitor
Monitor Problem
its a power prblem
u need to change the internal power conector
Sep 03, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Samsung CRT Blank Screen
1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
2. check 5V supply,change 5v Regulator.
Aug 19, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
