Did anyone find a solution to this problem? my taurus sho also cuts out and really acts up once it gets warm. plz report back if anyone has figured this out. thanks
Do you have spark after it dies? Possible ignition module.
no was not the ignition module replaced it still same thing
i have the same issue. i was told it was either a cam shaft sensor or crank shaft sensor. i have driving with the heat on hi to get around. i changed different igniton stuff already. im trying to find out if it would be quicker to change sensors or change motor. [email protected]
I have the same problem. Once the car warmes up The ignishion system cuts in and out. I have replaced the coil, crank angle sencer and the ignition module. Didn't seam to affect it at all.
i have the same problem. Once the car warmes up the whole ignishion system seams to cut it and out. the RPM gauge cuts in and out with it. It does not like to start till the engion cools back down. I replaced the crank angle sensor, ignition module and the coil and no luck
not sure just bought the car this is just what the guy said it was doing
