Question about Microwave Ovens
I have a simpson Alpha stove. model number: 2U608W*00 the problem is, i can only use one element at a time. when i turn all 4 element or oven and element on at the same time, the power will cut off, and automaticlly back on in a couple of minutes. what's the problem is this? many thanks.
MicrowaveSvc
  • 9098 Answers
SOURCE: Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Posted on Feb 08, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: After turning the bright light on above the stove
You may have shorting keypad or a problem on the control board.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply back directly to me for free help and tips.
Please include your full model number and color.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: My KitchenAid microwave oven's model
Either your high voltage rectifier or magnetron (or both) has failed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Posted on Oct 03, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a GE Spacemaker
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 25, 2011
  • 403 Answers
SOURCE: Whirlpool Accubake Stove When oven is
You need to replace the sensing probe.
Posted on Jul 17, 2011
Samsung microwave model # ME21M706BAS/AC How to set the clock
1. Press the Options button.
2. Press the 9 button.
3. Press the OK button.
4. Use the numeric buttons to enter the current time. You need to press at least three numbers to set the clock. For example, if the current time is 5:00, press 5, 0, 0. The display will show 5 : 00.
5. Press the OK button.
Here is a link to download the user manual:
http://downloadcenter.samsung.com/content/UM/201712/20171229143437765/2017.12.22_ME21M706BA_AA_EN-MES-CFR.pdf
Feb 09, 2018 | Samsung Microwave Ovens
How do I replace the grill element?
Unplug the Stove in the back, unscrew the element, unplug the wire and replace elemnt.
Nov 24, 2015 | Zanussi ZMC30STQA Convection Microwave...
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
This an old range with side by side ovens which work perfectly. the 4 burners slide out, all 4 elements will heat, but do not get to a high heat, is there a control which affects all of the elements ...
Hi and welcome to FixYa, I am Kelly.
This sounds like your missing 1/2 of your input power. Go to the main CB panel and cycle the Range CB to OFF by pressing it hard to off and then back on. Test your burners again.
Still have the problem? Start looking in the area of the house to oven power connection / terminal block in the back of the oven for signs of HOT / burned terminals.
Still have the problem... Last check is to check wiring in the main controls area.
Without your model number this a VERY generic response but when all burners present the same symptom it is usually input power or control related.
If you respond with a model number I wil see what I can find that may help you troubleshoot your Oven.
Thank for choosing FixYa,
Kelly
Mar 23, 2011 | Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
I need a replacement element (8 inch) for my Kelvinator range (model no. KRS J3L-1)
Hi, W/D here.
Here's the easiest way that I know of to repair your stove:
Remove your element. Most can be removed by lifting the element on the side away from where the leads disappear under the stove top, and then pulling it out of the plug-in socket.
Take the element with you to one of the larger hardware stores, and locate the elements that have your style of terminals. The elements are generic; that's why you needed your old one. I have replaced dozens of elements and have found the generics to be every bit as good as one ordered, and cheaper, too!
Best regards, --W/D--
Jan 31, 2011 | Microwave Ovens
The oven takes a long time to start heating. somtimes if we turn a burner on and off the oven starts you can see the starter element glowing
If this is a gas oven, and the starting element you're referring to is the ignitor, replace the ignitor, it's "worn out". Depending on your make and model the ignitor is usually either flat or round. Part numbers respectively are 12400035 and 4342528. The ignitors can be substituted for the ones with the same shape regardless of the brand.
Dec 18, 2009 | Microwave Ovens
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
