Question about Yamaha RX-V463 Receiver
The function "playing video sources in the
    Brigadier General:
  • 8,546 Answers
Page 36 of the manual explains it.
Posted on May 29, 2011
I am trying to hook my pioneer vsx-455 up to my samsung dlp-hd tv and have no idea which pre-outs to use.any help would be greatly appreciated.or do i need to go through the cable box and if so how?
Ok. Where does the TV programming originate? Antenna, TV, or (usually) the Cable Box. I'll tell you sight unseen, no TV ever adds to the audio experience. many of us watch on monitors so that would suggest that a TV can play absolutely no part in the high-end audio experience. It's specialty is video with basic audio capacity thrown in. A Cable Box is for all purposes a digital audio and video source with separate outputs for each. Keeping with my practice I'd run the BEST VIDEO (and minimum audio in case you want to use TV speakers for that source) from each video source to the TV (it has multiple inputs, right?) and the BEST AUDIO (no video) from each source to the receiver. One video connection from the receiver to the TV for set-up/control. This requires some switching on your part to watch different sources but it eliminates troublesome and unnecessary routing and handling of the individual signals.
Nov 08, 2011 | Pioneer VSX-455 Receiver
Tip
Play flash(flv/f4v) videos on iPad 2
The newly released iPad 2 does look like a very well-designed and beautiful device. It may be used to search the Internet, watch movies and videos, listen to music, use art programs, read/send e-mail, read e-books, play games, keep a calendar, watch TV, use maps, or to look at and organize photos. The iPad, however, won't run flash content at all. That means you won't be able to watch videos from Hulu and the adobe flash is kept away from your touch. Still you could watch the flash videos downloaded from Youtube or Hulu on iPad------Pavtube FLV Converter could convert flash videos (*.flv, *.f4v) to H.264 or MPEG-4 encoded videos that are compatible with iPad. The following guide tells how to <a href="http://wannasoft.com/Pavtube-Video-Converter/">convert flash videos to play on iPad 2</a> with Pavtube FLV Converter. <br /><br /><br /><b>Step 1. Run <a href="http://wannasoft.com/Pavtube-Video-Converter/">FLV to iPad Converter</a></b> <b>and load in flash videos. <br /></b>First, you Install the FLV Converter and get your FLV files ready,<b> </b>run the app<b> </b>and click "Add" button to import FLV files to the app (or simply drag the source files to file list.) Double-click on it if you'd like to preview a file or take some snapshots. <br /><br /><b>Step 2. Set output format to be compatible with iPad</b> <br />You will then tick the format bar and choose an appropriate format for iPad. MP4, MOV, M4V encoded with H.264 and MPEG-4 are available. Specify output format and next output path. Click on "Settings" button in case you wanna change its codec, bitrate, size, frame rate, audio channel, etc. For example, set audio codec as AAC. <br /><br /><img src="convert-flash-video-to-play-on-ipad_clip_image002.jpg" /> <br /><br /><b>Step 3. Convert the FLV, F4V videos</b> <br />When all these are done, you can click "Convert" button to start. If you'd like to put some flashes into one file, simply check the box "Merge into one file" before clicking "Convert". After conversion finished, you may sync the converted video clips to iPad for playback.
on Mar 11, 2011 | Computers & Internet
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
How can i connect my kenwood vr-505 to my t.v only
I assume you mean you want TV-related sound to play through the Kenwood.
It's in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-505-Receivers-manual/id/480ag214/t/2/
I personally would recommend minimum TV involvement in sound and minimum receiver involvement in video, but that's just me.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don't even HAVE audio (monitors, for example). The receiver only NEEDS a basic composite video output to the TV so you can use the TV for setup and control. You COULD run vanilla stereo audio to the TV from the Cable Box for watching Oprah.
I run all of my best DIGITAL audio directly from the sources to my VSX and the best DIGITAL video directly from the sources to the TV.
Mar 25, 2011 | Kenwood VR-505 Receiver
Only one the left channel sends out a signal to the speakers -- whether using the "A" or the "B" options. Is this correctable without having to purchase a new unit?
Is it on all audio sources or only certain ones?
FM is the best source to use for testing basic receiver function because you can't mis-wire it.
If it's only analog source(s) doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute Switch. It
Feb 06, 2011 | Audio Players & Recorders
Left front and left rear speakers do not work, they produce some sound but mostly static. The "phono" rca jacks also do not work.
First off make sure that the cables you are using are functional. Also,check and verify the locations of the connections. You need an audio output from your source to an audio input at your receiver. If you run a video output from your source to an auido input on your receiver that will create strange sounds
Jan 07, 2011 | JVC RX-318 Receiver
How do I get tv audio to play on the home theater system
This HTS isn't really designed to be a versatile processing center for external sources.
My advice is to treat TV-related audio as any other audio component. First, its best source will be the first device that processes it - cable box, sat box, gamebox, BD etc.
I'd also bypass this unit's video connections for those video sources and run them directly to your TV or monitor. The best unit for each function (audio or video) should get the best source directly.
Get the best-quality digital audio that unit will provide and run it into the HTS. This HTS has one optical (TOSLINK) digital input, so THAT would be where the best digital audio would enter it. Hopefully, your source uses optical audio output. Otherwise... analog audio is limited to stereo or derived Dolby Surround.
Sorry.
Dec 23, 2010 | Samsung HTC550 Theater System
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
How do you access the video mode in order to watch a movie on a dvd play or play a video game?
Hi, usually the function button on the remote control to select the input mode / source is a circle or a square with an arrow pointing into it (see below).
b74fea7.jpg Each time you press this, the next available source is selected in a set order, e.g. TV / AV1 / AV2 / HDMI / PC
If using a SCART interface for your DVD player, the TV should automatically switch to the DVD source when you activate the DVD player (take it out of standby).
Nov 26, 2009 | Sylvania Televison & Video
Put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Oct 11, 2008 | Pioneer DEH-P4700MP CD Player
Yamaha RX-V463 Receiver Logo
54 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
