Question about Juki DDL-8700
My machine isn't sewing the string is just straight and laying there when I try to sew it it just keeps flowing out of the machine.
  • 33 Answers
Adjust stitch length and stitch tension
Posted on May 29, 2011
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
Tip
Sewing Machine Needles
Did you know sewing machine needles can be machined wrong? If your machine isn't picking up the thread, try replacing the needle. If the scarf isn't in the correct place, the hook can't pick up the thread.
on Mar 05, 2015 | Singer Sewing Machines
How to retime a brother 900d sewing machine
Breaking threads isn't necessarily a timing problem. Check for burrs.
Nov 11, 2012 | Brother Innov-Is 900 Sewing Machine
Singer simple needle keeps snapping
Type in sewing machine problems on 'youtube'. There are lots of demo's inc. a great chap in his 50's. Explains thoroughly what's happening. Free manuals as pdf if you GOOGLE for lots of machines.
Jan 07, 2012 | Singer 3116 Simple
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
How do i insert needlewhich way round into machine newholm sr2000
Needles are normally inserted with the flat side of the top part facing away from you. I've yet to see a machine that it isn't inserted that way in 30+ years of sewing. If, for some reason, the machine doesn't sew or isn't sewing well with the needle inserted that way, you can always flip it around and try the other way. But start this way first. I'm certain it'll be the correct way on your machine as it is on every machine I've ever come across.
May 19, 2011 | New Home Sewing Machines
Hi iam not sure how explain my problem with my sewing machine.when i try to sew the strings does not comes stright. it gets messed up the top comes ok but the bottom of the layer comes out all strings...
If I'm understanding the problem right it sounds like you have no tension on the bobbin. Take it out and see if the thread has any resistance when you pull it out. If you hold it up by thel thread and let it dangle and it just drops to the floor the tension isn't right. Check and make sure it is threaded correctly and tighten the tension. Test it again and when you dangle it, it should drop a bit with resistance when you hold it by the thread.
Also check that the top tension isn't too tight, but in this case it is more likely that the bobbin is too loose. And check to see if the dogfeed (the teeth that comes through the plate opening under the needle) is up and moving the material through the presser foot. If the material isn't moving at all it will sort of stitch "in one place" which will give you a bunch of threads all knotted up underneath. If those underneath threads are loopy that is a sign the bobbin thread is too loose (tension too loose)
Apr 21, 2011 | Kenmore 15516 Mechanical Sewing Machine
Everytime i try to sew anything my sewing machine gets the string all tangled up and just stops.. I just want to sew a straight line and idk how exactly to put the settings in a straight line. So that may...
Download a copy of your manual for free at www.brother-usa.com under support for home sewing. Follow the steps for threading because you do not have it threaded right. Save a copy to your computer and enlarge the diagrams for easy viewing.
Dec 28, 2010 | Brother XL-5130 Mechanical Sewing Machine
My white superlock 734dw keeps dropping the 4th thread!!
It may be that your presser foot is not alligned with the cutter. This is the problem that I am trying to solve now. My presser foot is not lining up with the blade and it does what yours do. ok then nothing.I have changed the needles and cleaned it and oiled it. I have taken apart the foot and assembled it and when I put it back on it wont allign to the blade and the book is NO HELP at all. I won't pay for an answer but when i get it i'll lpass it on to you. OK.
Aug 14, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Juki DDL-8700 Logo
67 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
