Question about Sceptre NAGA II X20WG 20 inch LCD Monitor
Hi My monitor that i have used to let us shut off the monitor manually, it no longer does it reads key lock whenever we try to turn it off and if we try to adjust any settings it will read key lock in the middle of the screen and will not do anything for us.
    Scholar:
  • 101 Answers
I'm not aware of any ability to lock the keys on any monitor I've seen. I've not used a lot of Scepter monitors but it seems like a rather pointless option to have. So unfortunately the monitor seems to be malfunctioning and will have to be repaired or replaced.
The only thing i can suggest trying is unplugging the monitors power cable for a few seconds in hopes it will reset the monitors control buttons.
Posted on May 29, 2011
Car was running fine. had battery disconnected & reconnected. Key will not turn in ignition switch. getting a reading that says steering lock malfunction, stop car safely
Hi Doug...
Not currently all up on Saabs...
Many years since I worked on one...
but reading the owners manual (ALL 288 Pages)... has convinced me your configuration is fairly close to the BMW ...
(with which I am FAMILIAR).
Even though you have a "chip" key...
the lock still ought to work manually.
Battery NOT your trouble...
That would definitely give you OTHER problems
(specifically key "NOT RECOGNIZED").
On other cars ... I have experienced a similar issue caused by the steering column holding the lock lever from releasing:
If the wheels are turned against a curb... or hard in any direction... TURN THE WHEEL HARD (just "hard"... as in steering... no Samsonite Gorilla here) in THAT SAME DIRECTION and try to wiggle the key in the lock as you attempt to turn it... then try against that direction... again "HARD".
Failing that... jack up the front of the car until you can see some free-play in the steering wheel... by pushing the front tire back and forth... then try the key.
Hope this helps
Saab Owner Manuals Factory Warranty features and options and maintenance...
Mar 02, 2016 | 2008 Saab 9-5
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Hi, I have a 1999 Dodge Caravan, I lost my main set of keys with the clicker and chip key. I now only have one spare key. The alarm was accidently set. I can get in but the alarm goes off and the car will...
Try locking and unlocking the rear tailgate lock with your key. That should turn off the factory security system. As for the keys, if you no longer have a key with a 'chip' in it, the vehicle will not stay running, until you replace the 'chip' key. The immobolizer system needs a key with a 'chip' to work.
Oct 14, 2010 | Dodge Caravan Cars & Trucks
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
There are three servers (2 G5s and 1 G4) these servers share a single monitor but i don't use any kvm switch.. I manually switch the connection of the monitor to access the three servers. i use G4 most of...
Do you try disabling Screensaver feature on those two servers...might that be causing display prob, if you try pressing any key or it would show screen
But still if it is not working, Check Power saving feature for these two Server, turn off featue to turn off display and harddisk if computer is standy by for......mins
Hope it resolve issue, Best of Luck
Oct 09, 2009 | HP ProLiant DL360 G5 (457922-001) Server
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
Microtek monitor 997m
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Jul 01, 2009 | Computers & Internet
Sceptre NAGA II X20WG 20 inch LCD Monitor Logo
149 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
