Question about Sibelius 6 Notation Software Educational Edition PhotoScore Ultimate 5 Music Scanning Software E (99106152900)
I have Sibleius 6 and a new Roland Fantom keyboard synth which has it's own USB Port. I can get my Roland to interact with my PC (Windows XP) but I can't seem to get it to work with Sibelius 6 in Flexi Time. Do I have to go out anf buy a MIDI USB interface or is there some way I can use Flexi Time with a direct connection from my Roland Keyboard to my PC without the interface. Please advise.
2 Suggested Answers
  • 11 Answers
SOURCE: Installation problem with Sibelius 5 on Vista
Errors on install of sibelius:
Luckily, there is a installation assistant that solves this problem! You can visit the help page here, there you can download an install assistant. Once downloaded simply run it and follow the on screen instructions.
For a direct link to the assistant click here.
Errors on start up of Sibelius:
If you have AVG antivirus, Google Desktop or Adobe acrobat pro installed. Then you can experience start up problems when opening sibelius.
I found that if you download updates for all three programs (or just the ones you have). Then sibelius will start up properly.
I had this problem on an Acer laptop -
I just uninstalled google desktop as i did not need it and updated avg.
Posted on Jan 04, 2009
Hey, my synth fantom x6 now dead condition, Roland service center (kolkata) fix the problame. said it's flash rom chip is bad and its not avilable in market!! So..pls suggest me what I do??
Contact Roland directly. Speak to their customer service department in your country. I beleive this is the info-
If it's just a parts availablitiy problem, remember that Roland is a world wide company. Contact Roland in other markets, starting close to you and expanding out. Somebody will have it. I'm in the USA and often source parts from Canada, for instance.
If the instrument is truely dead, you can always sell it for parts to other users. Ebay would be a good option.
Mar 24, 2016 | Roland Music
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
I would like to connect my fantom g6 to logic and be able to play the sounds from logic through my fantom and record into logic.
If you hook it up with the USB cable Logic should recognise it. You may have to select it in the Audio Preferences as your Audio Interface.
Jun 30, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
My roland fantom xa turn on but dosn't log in it just show something like roland fantom xa in continue slide show
when i turn on my roland xa it's going on but it show on screen xa fantom and it gonig hang what i do
Feb 25, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
When i turn on the Fantom G8, it shows a blue screen with this message "Roland Fantom (S/W updator) (B)
Somehow you have activated the mode to download a new operating system into the unit. It likely is expecting the new SW to be presented form source such as MIDI, USB, or stick.
Get it out of that mode before something gets clobbered. DO a Factory reset which will consists of holding certain buttons and turning power on. Find this procedure in your user manual.
Feb 12, 2011 | Roland FANTOMG8
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
Roland RD-700SX as MIDI keyboard
Theres a good article at If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
I have a Roland Rhodes Model 660 keyboard/synth and cannot find a user's manual has a good selection of manuals.
Apr 23, 2009 | Music
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland xp 50 storage medium problem
There is a solution that reads and writes on CF cards. It's call HDM uniflash or something like that.
I didn't try in my xp50, but others says it works.
A bit expensive for my taste, and maybe just for handy hands...
Jun 11, 2008 | Computers & Internet
Sibelius 6 Notation Software  Educational Edition  PhotoScore Ultimate 5 Music Scanning Software E (99106152900) Logo
111 people viewed this question
Top Sibelius Computers & Internet Experts
Martin Murray
 Russ Hill
Russ Hill
Are you a Sibelius Computer and Internet Expert? Answer questions, earn points and help others
