Question about Dometic Rooftop RV Air Conditioner
We have a Dometic Duo Therm airconditioner on our RV. The model number is 620515.331. When I climbed up on the step ladder to have a look at the roof of the coach, I noticed that encircling the unit, it looks like a kingsize bird's nest replete with twigs, grass, etc. Nothing seems to be alive in there, so we can only hope that all this stuff was sucked into it when the air was on. We have only used it a few times. We have no manual with the info from the RV dealer. Can we take the screws out that go around the cover and get at the shrubbery?
    President:
  • 1,654 Answers
Yes once you remove the screws the shroud should come right off. The cover is just that, the cover for the unit. You might think about putting some screening around the opening to keep this material out.
Posted on May 29, 2011
Duo therm airconditioner cleaning coil
spray coil cleaner on surface of coil with fan running allow it to pull cleaner in coil then rinse
Aug 23, 2012 | Dometic Rooftop RV Air Conditioner
Duo therm rv airconditioner pulls 17 amps, with compressor running. It cools very well though.
Check incoming voltage first to make sure it's not dropping under load, or low to begin with. Any poor voltage or long runs of extension cords could be causing voltage to drop, thus raising amperage draw.
Jul 04, 2011 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Duo Therm Model 59516.531 RV Airconditioner not cooling
The refrigerants in these units is R-22 But there is no reason to think the system has a leak. You need to confirm that the comprerssor is running. This requires an ammeter. If you don't have one call a technician.
Ray
Jan 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
112 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
