Question about Video Game Consoles & Games
What do you do when kinect sensor has says it has insufficient power?
  • 51 Answers
It only says this if you are using it on an old xbox 360 because it needs a separate power supply.....it will only run from usb in the new slim models
Posted on May 31, 2011
5 Suggested Answers
evan89
  • 356 Answers
SOURCE: the kinect sensor has insufficient
Look at this
http://segmentnext.com/2010/11/07/kinect-troubleshooting-guide-errors-setup-sensor-speech-space/
It is a complete Kinect Troubleshooting Guide
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Posted on Mar 06, 2011
scrodamoon
  • 659 Answers
SOURCE: why does my kinect say
Try plugging it in with the power adaptor that came with it. I am sure that you probably have it plugged into the back of the system of the slim model unit. so try that and hook it up through usb there could be a issue with your kinect port.
if that does fix it I would call microsoft and get it repaired under warrenty.
Posted on May 30, 2011
  • 90 Answers
SOURCE: I have a xbox 360
A likely reason this problem is occurring is that you are drawing to much power from a single outlet. Try plugging in your Xbox to a different electrical socket. If this problem persists please comment so that I can try to further assist you.
Posted on Jun 13, 2011
beatmeistah
  • 12 Answers
SOURCE: XBox Kinect says insufficient power
Red light on the Kinect sensor Last Modified 16/05/2011
kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive the following error:
The Kinect Sensor has insufficient power (C0051202)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.? ? ? Solution 2: Check the cables ? ?new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light, your cable needs to be replaced. Contact Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, the sensor needs to be repaired. To start the online repair process, go to myservice.xbox.com.
Posted on Jul 04, 2011
How to replace kincet sensor?
To replace how? By something broken in it or just a new kinect? If a new kinect then just buy the sensor without the power supply to save money ,and use your old power supply to turn it on
Jul 17, 2014 | PDP Kinect Sensor Kit for Xbox One
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
My kinect does not turn on the light stays on red
Try unplugging the kinect and then the x-box power for a few minutes. Then plug the kinect in before reconnecting the power. If that doesn't work you may have to contact microsoft support, there should be a phone # on the package.
Sep 11, 2011 | Microsoft Kinect Sensor for XBOX 360
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
XBox Kinect says insufficient power I've tried unplugging and plugging into a single outlet but same problem. What can i try next?
Xbox 360 S console
Jul 04, 2011 | Video Game Consoles & Games
I have a xbox 360 Kinect and there is a problem with the sensor it says on the tv. The Kinect Sensor has insufficient power can you help me? I have tried to unplug it and every thing but nothing will work.
Jun 13, 2011 | Video Game Consoles & Games
Why does my kinect say that it has insufficient power?
May 30, 2011 | Video Game Consoles & Games
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
Trying to connect kinect.... its saying that it has insufficient power
Hi Eddie,
Try with different USB ports if you are using old XBOX and getting message as " insufficient power". It seems to be a adapter issue why don't you visit store and exchange the XBOX 360 Kinect device.
Thank you for using Fixya.
Xbox 360 kinect Games List
Dec 25, 2010 | Microsoft Kinect Sensor for XBOX 360
Video Game Consoles & Games Logo
292 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
