Question about Electrolux Washing Machines
Electrolux EWF 1074 - the white plug won't come
Just had the exact same problem. Thought maybe it wasn't supposed to budge, but I got the pliers in there, and out it came!
Posted on Oct 04, 2011
    Brigadier General:
  • 6,277 Answers
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 29, 2011
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
Heating element
Remove back plate and you should see it middle bottom of machine ,it has two Spade Terminals with two wire fitted to it also an Earth onto its case,You can look up heating elements on the net, this will give you some idea of what they look like and cost.
Jan 15, 2014 | Electrolux Washing Machines
My Electrolux EWF 1074 wont spin I have voltage at the motor but no go
If you have been able to check the motor with an external supply and found that it was working , then perhaps the control board has to be checked. Please test the motor, if it runs freely perhaps the drive is stuck , check the spindle assembly , could be jammed or the bearings could be faulty
Nov 21, 2013 | Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
Feb 29, 2012 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
175 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
