Question about Sony CRX330E CDRWDVDROM Combo Drive
Drawer does not open when button pushed. Access ligght blinks. Same when rod inserted in hole under drawer.
  • valandgordon May 29, 2011
    The problem is getting at teh rubber belt. I can take the cover off the bottom of the drive, but this does not expose the rubber belt. I can't work out how to get the cover off the top (and sides, since it is one unit) to expose the workings of the drawer mechanism.
    Sergeant:
  • 207 Answers
You should replace the rubber belt of your drive
Posted on May 29, 2011
  • melndream
    melndream May 31, 2011
    It is impossible to take off the cover of the drive when the tray is not ejected. Please eject the CD tray first by pushing the emergency eject hole with a straightened paper clip then open the Optical Drive unit cover.
  • valandgordon May 31, 2011
    Thanks. I'd already tried that before removing the drive from the computer. I needed a drive sooner rather than later, so I bought an new one.
How do you open the CD drawer?
There is a button on the drawer. It is located near the center toward the bottom. It is often difficult to see. I painted mine white using "white out" error correction liquid. If the drawer is not opening after pushing the button then use a paper clip to aid in the opening. Insert the point of the paper clip into the hole that is next to the drawer eject button as described above.
Oct 19, 2014 | Acer Computers & Internet
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
I can't open the cd drawer
If pressing the button on the CD/DVD drive does not open the drawer you can look for a small hole on the face of the drive, usually just below the drawer and about 1/3 of the way in from one side. Straighten out a paperclip and insert it into the hole. It should go in about a half inch then stop. Push a little harder and it will travel farther in and release the drawer.
Nov 02, 2013 | Computers & Internet
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
How do i unlock my system
under the Dvd drawer tray towards the right hand side where you have the open close button just next to it you will see a small pin hole. you can insert a safety pin in the pin hole and push it so that you can open the DVD drawer. Good Luck
Feb 07, 2012 | Gigabyte Intel G31 775 DDR2 )
Cd tray tries to open butacts like its stuck
Take a Norwegian paper-clip.
Straighten one end.
Insert that end into the small hole in the faceplate of the CD-drive, until you feel resistance.
Push it another 1 centimeter (1/4 inch) against the resistance.
This will "unlock" the drawer.
Push the open/close button, to fully open the drawer.
Remove any CD disk.
May 09, 2011 | Computers & Internet
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Won't open
Hello, look for a small hole somewhere near the centre of the cd drive drawer. Straighten out 2" of a paperclip, and insert the straightened end into the hole until you meet resistance.Push firmly and the drawer should begin to open.The more you push the paperclip in, the more the drawer will open.
Regards,
nicam49
Nov 08, 2010 | Lite On SOHR - 5239V (SOHR5239VBULKB)...
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Sony CRX330E CDRWDVDROM Combo Drive Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
