Question about Cycling
Don't know valule of my race bike - Cycling
  • jfrogg1818 May 29, 2011
    It is a haro monocoque 1997 ser# 020 raced for three year its in exlennt con allumm polished
    I ve look every whear and I know the serail number of my bike the factroy riders didn't even have this frame at the time they wear coming out ser# is 020
    President:
  • 1,961 Answers
Hello jfrogg!
Before a used frame would costs only $350.
Today, at Ebay, a used frame would costs around $410.
see it from the link below:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160577351370+&clk_rvr_id=235929923656
a used Haro 1997 monocoque BMX would cost $1,200, almost the same with other serial numbers
http://cgi.ebay.com.au/HARO-1997-MONOCOQUE-BMX-EXCELLENT-CONDITION-/220747535227?pt=AU_Sport_Cycling_Bikes&hash=item336594137b
Posted on May 29, 2011
  • 4,472 Answers
If you give me the make and model as well as condition and usage. I would be glad to try and get you the value of your bike.
Thank you,
Lee
  • Lee A.
    Lee A. May 29, 2011
    easily worth 700$. I would have to see a picture of the bike. I believe they were like 900$ new. Going to the right person and depending on how mint and original the bike is it could be more.
    I had an old old haro back in the day. Awesome bikes! I would keep it but if you sell it good luck. Try the old school bmx forums or ebay. If you have any other questions let me know.
    Thank you,
    Lee
  • Lee A.
    Lee A. May 29, 2011
    I'm not sure what your looking for? I gave you a pretty thorough explanation of the bikes worth. There are a lot of factors when selling a bike. Like i said at least 700$ for it complete and it could easily go up to a 1000$ or more.
    Thank you,
    Lee
Gearbox missing neutral
You want a solution, but this is all the information you can supply?
Did you just buy this bike?
If it's one of my old bikes, you will have a lot of trouble finding neutral as I modify the shift spool detents to make neutral extremely hard to find. This mod is done for racing. BUT - I don't race Suzukis, so this is not my old bike. It is possible that someone else has removed neutral from the shifting spool detents though - it used to be a pretty common modification for racers.
Without having more history, I don't want to waste any time speculating on any other solution. I would like to know if this is a new bike to you or at least a little more info on the problem and some history of the bike. Put in a little effort.
Oct 16, 2011 | 2003 Suzuki RM 250
I have a 1979 kz400 and i am replacing the bearings in the neck i got the bike with it tore apart already and i am not sure if i am missing any parts and how it all goes together.thank you
Hi will...this is a job you can't afford to make mistakes on, only to find out later the hard way, worse case would be an accident and you are injured.... I don't know what parts you have now, or how it was taken apart. You should have upper and lower head bearings, several washers, flat & star, some bushings and seals, retainers and lockdown, dustcover...also bearing races. Are the new bearings tapered or non? Have the old bearing races been removed or still on the shaft? I recommend you get a shop manual and follow step by step instructions, clean, lube and torque everything to factory specs. The proper torque is VERY important ... better to be safe than sorry when it comes to steering head repairs...good luck, i hope this helps
Jul 12, 2011 | kawasaki KZ 1300 A3 Motorcycles
It's an 01 ktm 400 exc. I can't shift into first gear and I'm getting a ratting sound sometimes. The bike still shifts beautifully up and down from second on, but when I try and downshift into...
Thanks for contacting FixYa with your inquiry.
Check externally for the obvious things first like a bent shift lever or lever re-installed in a position interfering with frame or something preventing engagement into 1st gear. I'm never that lucky.
More than likely you have either bent a shifting fork or lost a tooth on a gear or something on the shift mechanism internally is bent, broken, or has lost a clip. Drain your oil and check the plug magnet to see if any metal shavings, fragments, or parts appear.
You will most likely have to pull the engine and split the case and replace parts. You can take it to a shop or if your handy do it your self. Take a look at the link to the parts fiche and determine your preference.
http://cyclehuttktm.com/FicheFinderNew/FicheFinder.aspx
2001/400/Engine/Transmission II (Don't know if your bike is a SX or EXC Racing)
2001 > 400 SX RACING > ENGINE > SHIFTING MECHANISM
You can also order a repair manual from this site or ask your dealer
http://www.repairmanual.com/KTM.html
If we can provide other information or service please advise.
Kind regards,
TF
Jul 12, 2011 | KTM Exc-Racing E 400 Motorcycles
2001 honda shadow what kind if fuel should i use
Regular unleaded should work well in your motorcycle; it may actually start and run better with regular than with premium gasoline.
The big wild card, however, is the amount of ethanol in the gas you are buying. Your bike would definitely run best on "pure" gasoline that contains little or no ethanol, but that's getting harder and harder to find. Personally, I have noticed that my bikes have started harder and run worse as the ethanol content in gasoline has increased. That's one reason I actually recommend staying away from premium, which sometimes has more ethanol in it than regular (it raises octane). I prefer to keep my bikes stock, rather than messing with the carb jets to compensate for the different performance curve of ethanol-blend gas.
If it's available in your area, you might try running your bike with some Cam2 racing gasoline to see if that makes a difference. You don't need the extra octane in that fuel, and some varieties of that fuel may still contain lead (a no-no for your engine), but it doesn't contain ethanol, as far as I know. Double-check with whoever is selling this fuel in your area to make sure you're getting the unleaded stuff. If you find that your bike runs well with this fuel, you might consider blending a bit of it with pump gas on going-forward basis.
May 31, 2011 | Honda RC 51 Motorcycles
Who often do i change the oil on a kx250
If you race this bike then I would suggest at the end of every full race meet dump the oil and filter as apart of the clean down to put away for next race day routine obviously fill it back up when due to race next
If your just recreational use and not going on the rev limiter all day long then about every 2 - 4 hours of running time would be OK
simple rule of thumb with the four stroke Motocross bikes if you love the bike and you can afford it change the oil as much as possible you cannot change to often in my opinion (just don't over tighten the sump plug just nipped up is fine)
cheers mate happy riding
May 24, 2011 | 2005 kawasaki KX 250 F
2008 yamaha yz 125 carburator flooding out, cleaned carb, checked reed valve, still flooding out?
You say it's flooding - is fuel coming out the overflows? If so, you might need to replace the needle and seat, but based on the age of the bike, I wouldn't think you would have to do that yet. Even with a bike that is raced, you can get many, many years on the needle without having to replace it - unless something damaged it. Inspect the needle and seat closely for nicks or imbedded **** in the sealing area. Also - I assume you set the float properly. This is an important step. Personally - I think the factory setting is too high - since about 2001 I have set the float 2MM lower than recommended. Otherwise you will have fuel pouring from the overflows on the faces of jumps or in the whoops.
If the engine is "flooding" - it could be down on compression which will make it run rich. Or you might just have to re-jet but I would only re-jet if the engine is fresh. You can also try running a B8ES pluf - it's a step hotte than stock and what I ran. Keep in mind that the ring in a 125 doesn't last long at all. There's only one ring. I would replace the ring before each race when I was running 125s - this happened every week during the season. 2-3 ring replacements per piston, 4-6 piston replacements per cylinder.
If you provide more info, I can give you a better answer on your exact problem - I don't know if I really know exactly what the problem is.
Scott
May 20, 2011 | 2008 Yamaha yZ125
Location of oil filter and what kinda of oil on a 2003 Honda CR125R 2-stroke
G'day.
There is no oil filter in a two stroke. Your bike has two types of oil for the engine.
In the gearbox, it uses a light viscosity 2 stroke motorcycle gearbox oil.
Then you have the oil that you pre-mix with your fuel(to lubricate the top-end & crankshaft bearings).
Oil for your bike is best purchased from a motorcycle shop- this is a racing bike that requires race type maintainance.
The better the maintainance the longer it will last.
Things like,
Keep the chain lubricated.
Keep the air filter clean & oiled correctly with propper air filter oil(this is REALLY important).
Use high octaine fuel-(if in Australia like me-no ethanol fuel- 98 octaine).
Use the best quality 2 stroke oil you can afford-preferably full-synthetic.
Here is a link to parts fishes(exploded diagrams) for your bike.
These will help you see all the parts & gives a good idea on what goes where.Click on the part name & it will show you a picture. : )
http://www.mrcycles.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=2003&fveh=3243
If you have any other questions don't hesitate to ask.
Kind regards Andrew Porrelli
May 19, 2011 | 2003 Honda CR 125 R
How can 1 watch live racing at the races
I am glad to HELP YOU!
I don't know what kind of races do you have in mind [you've forgot to specify...] but I'd suggest you some useful links: THIS one, THIS one from Daytona, and also you can try JLC Internet TV [you can get it FOR FREE on THIS website]. All you have to do is to DOWNLOAD and to INSTALL that tiny software and you will get a lot of SPORT CHANNELS FOR FREE.
GOOD LUCK!
... and don't forget to RATE...
Apr 18, 2011 | IBM ThinkPad T60 Notebook
Cycling Logo
46 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
