Question about Dell Inspiron 1720 17" Widescreen Notebook, 2.0GHz INTEL CORE 2 DUO, WiFi, 3GB RAM, 640GB, CDRW/DVDR... (883585945788)
Dell 1720 says plugged in not charging , works fine on cord , now that battery is down will not work on battery alone . meter when pushed will light one white light then goes out. battery bad ?
Hello there.
Unfortunately, your battery is "dead". I used to have Dell notebook for several years, and on everyone, after 1 year, battery gone. If your battery is still under warranty go to official Dell service and let
they replace it. If not, you have to buy a new one, and it is at least 130$.
I hope I was helpfull.
Sincerely,
Steve TM
Posted on May 29, 2011
Battery won't charge
there can be 2 probs
  1. your charger must be repair .
  2. your life of your laptops battery must be over.
Jun 13, 2011 | Dell Inspiron 3500 Notebook
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
Dell 1720; battery meter says plugged in not charging. The comptuer is running fine. 91% left in battery. Already checked device manager, drivers, wriggled the charger cable, plugged in and out several...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Dell Inspiron 1720 JetBlack T5450 Laptop...
My Dell Inspirion 1720 laptop suddenly won't recognise its battery. It works when plugged in but turns off immediately if the cord is taken out. Do you know how to make it recognise the battery again?...
To recalibrate the battery, complete the following steps:
1. Plug in the AC adapter.
2. Allow the battery to charge until the Battery Charge light turns off, showing that the battery is fully charged.
3. After the Battery Charge light turns off, unplug the AC adapter.
4. Turn on or restart your Notebook.
Reset the BIOS:
1. Restart the notebook.
2. Tap the F2 key as soon as the manufacturer logo appears.
3. Using the arrow keys, navigate to Exit menu and select Get defaults values. press f9 key to load default settings
4. Navigate to Exit menu and select Save Changes and Exit
5.go to the dell web site and update the Bios>> http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R192441&SystemID=INS_PNT_PM_1720&servicetag=&os=WLH&osl=en&deviceid=12916&devlib=0&typecnt=0&vercnt=6&catid=-1&impid=-1&formatcnt=0&libid=1&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=264348
Click on the link and try to download the latest bios for the same.
Aug 06, 2010 | Dell Inspiron 1720 PC Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1720 17" Widescreen Notebook, 2.0GHz INTEL CORE 2 DUO, WiFi, 3GB RAM, 640GB, CDRW/DVDR... (883585945788) Logo
146 people viewed this question
Alun Cox
