Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
What are the carburetorr pin settings for a 334t tree saw
  • 252 Answers
Hi there
the base settings for hi and lo are 1 & 1/4 turn out from lightly seated
but make the hi setting just a fracrtion richer at top speed no load it should putter or 4 stroke slightly and the lo one should be about right buyt should pick off nicly when you stab the throttle quickly with no hesitation
note do not sett hi mixture setting to lean 2 top nol load or when you place it under lood it will lean out further and destroy the piston and rings
cheers pauly46
Posted on May 29, 2011
Tree pruner saw
There are tons of Youtube videos about tree pruner saw
like this
Yeoman Telescopic Tree Pruner and Saw
Do google search for
Youtube Tree prunner Saw
May 27, 2015 | Saws
Crafsman chainsaw 358.360280
Sound like worn piston rings OR incorrect carb H/L settings
Nov 22, 2012 | Craftsman Sears Chain Saw Manuals Model...
I'm looking for a tree looking bookcase that I saw in a commercial
You can try this link: http://vrudloffphoto.blogspot.com/2011/03/tree-bookcase.html it has few types of "trees". I think it is a great choice for your home library (if you have one) or for your living room - it really ads a little humor to the room.
May 30, 2012 | Furniture
You can try this link: http://vrudloffphoto.blogspot.com/2011/03/tree-bookcase.htmlit has few types of "trees". I think it is a great choice for your home library(if you have one) or for your living room - it really ads a little humor to theroom.
I am going through my husbands tools. We have a Ryobi Saw-all and I notice it has different blades. I can not find the manual. I simply want to change the blade for cutting iron that is currently inserted...
To change blades, a hex-wrench is required and you simply tighten or loosen the allen screw that holds the blade, but unfortunately the saw's design is a bit flawed. It takes a bit of "feeling around" to locate the proper position for the blade changing wrench because the fitting is not visible through the rubberized boot. You can certainly trim and prune trees with the saw, but make sure that the branch is at least 10% thinner than the length of the blade. I do not know your Manzanita tree, but if the wood is wet it should present no problem. Any power saw is extremely dangerous if used at an elevated height like on a ladder. If the ladder slips, there seems to be an almost unnatural tendency to grab for the saw and very often the moving blade. Take the utmost care at all times with power tools. (I have a friend who point blank refuses to use a chain saw unless both his feet are firmly planted on the ground, and he is over 6 foot).
Apr 21, 2011 | Garden
What's the best way to use my 16 in electric saw to cut off tree limbs?
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Sep 25, 2010 | Remington 16" Electric Chain Saw
The saw blade does not engage when trying to cut
Probably shot. You could buy parts, but now worth the time. Probably stripped the gears.
Jul 02, 2010 | Dewalt DC385B 18v. Cordless Bare...
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain saw stalls when engaging tree
if you have the and guard pulled back then it will stall.or if the chain is to tight it will do the same.
Mar 24, 2009 | Garden
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
41 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
