Question about Haier HWR08XC7 Air Conditioner
Haier air conditioner will not kick on to air conditioner mode, only the fan runs, but does not cool like air conditioner should cool, just blows as a fan.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
My air conditioner will not kick off.it runs cooling all the time.like if you set it on fan it continues to cool
The compressor relay is short and it continously running in all modes.You need to check this relay contacts to be short or the relay drive is constantly on.So check these units.
Sep 02, 2010 | Haier Heating & Cooling
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Air Conditioner will not cool. Only fan lights up
My AC seems to be running but it is not blowing cold air out. What maybe the problem?
Jul 16, 2009 | Dometic Rooftop RV Air Conditioner
NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
Apr 25, 2009 | Haier HWR10XC3 Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Haier HWR08XC7 Air Conditioner Logo
486 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
