Question about Canon PowerShot S51S Digital Camera
I shot video of the clouds last week in the storms from May 22. The video is great, but the clouds move in like the focus is re-adjusting in the video. It is very hard to watch in playback mode. I now editing the video and have tried to slow the speed and speed up the video and it is just too hard to work with in the edit process. I hope the canon Power Shot S51S is not going bad for video. Thank you,Steve
  • Canon Master
  • 5,412 Answers
If you were using autofocus for this, it is probable that there was insufficient contrast for the camera to maintain focus, causing it to 'hunt' for a viable focus point. Next time you try, set the lens / camera combination to manual focus, at the hyperfocal distance for the aperture you are using.
Posted on Jul 24, 2017
  • 255 Answers
SOURCE: "busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Posted on Sep 14, 2005
  • 17 Answers
SOURCE: Canon S51S power shot ... shutter stuck won't open . Help .
Either do a manual repair or take it in to a local servicer. Could just be some moisture built up inside.
Posted on Jan 04, 2009
  • 115 Answers
SOURCE: Canon 1000D wont let me shoot
It can be the cold or wet. try to keep it in dry place and change the battery.
Posted on Feb 04, 2009
SOURCE: Problem On How to Adjust Memory Capacity
first buy a new sd/xd card bcause the one that comes with you camera is truely **** because it can store almost nothing
Posted on May 21, 2009
SOURCE: Our Canon Powershot SD 780 is having a focus problem.
This might be a problem with the lens, I'm not exactly sure but I will get you in the right direction. There's a great site that just specializes in these Canon Powershot problems and they're terrific to say the least. If you go to you'll see your exact problem there for the canon powershot sd780is model. That should get you in the right direction to fix this problem. I really hope you can get help with this.
Posted on Feb 06, 2010
When i go to shoot an action photo like something that is moving the camera always delays. i focus on the moving target but when the button is pressed the subject moves out of the view and then the shot is...
OHH - I can met this problem before , the camera is trying to auto focus and in the time it does the focus the action has passed.
Take a light & speed setting - then switch to manual mode OR manual focus , this will eliminate the AUTO focus looking for best light reading distance etc.
Some cameras also have a "fast" setting which is usually a 'running man' icon - click this button and the picture will drop back to 5mpixels but it will take a quick shot instead of saving then scanning at a slower speed.
Mar 04, 2011 | Cameras
Hello, I have a Bushnell sportsman 3x9 mounted on a 22. I bought it new last year, but only took it to the range last week. I can't get the left/right cross hairs to move enough. At 25 yards, it shoots 9...
Start buy loosening the scope in the mounts. Loosen the front first to see if it is in a bind (left/right). Tighten it back down but not completely. Loosen the rear looking for some movement or popping sound. If you see a movement or notice some odd thing. check the mounting slots for dirt or dings that may cause an offset to the mount. If all is well. Go and start and zero for 13 - 15 yards. you want to be 1 1/2 inch hi. Now after each shot rap the scope with a screw driver handle or something solid, just to give the scope a shock not hard enough to bend it or dent it but shock it. Large scopes are meant for larger shock than a 22 produces, rapping the scope will help move the cross hairs and settle them in place. Hope this Fixya up. If it does help, please leave a testimonial. Thank you for using Fixya.
Dec 11, 2010 | Bushnell Sportsman 3-9X32 Silver Gun Scope...
I can get the elevation adjustment cap off. Is there some secret to elevation adjustment?
if the scope is out the best way to set it up is to clamp the rifle in a jig or hold it hard done on a sand bag,,,firs off the first shot at the bull and see were the shot hit the card,,,now without moving the rifle turn the scope turrets till the cross is over the bullet hole from the last shot,,,now again aim at the bull and shoot again,,,the shot should hit the bull,,if not reajust the scope as before,,,
Aug 31, 2010 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Rectangle in led screen green/ or yellow with exclamation
The camera doesn't have anything to focus on - especially if you're shooting the sky. The auto focus needs something with fairly defined edges to work. Try to focus on the edge of a well defined cloud, or focus on a tree or similar, half depress the shutter to lock the focus, then move re-frame your shot. Alternatively you can use manual focus. Hope that helps
Jul 24, 2010 | Canon PowerShot SX210 IS Digital Camera
Vibrations begin when turned on
Sony has discovered that some DSC-T20 and T300 Cyber-shot cameras sold in the United States may experience an issue with abnormal internal vibration and an inability to properly focus and take pictures. For cameras affected by this issue, Sony will provide free repair until July 17, 2011. In certain units, the lens cannot adjust properly due to a mechanical failure in the lens mechanism. When the automatic features of the camera attempt to adjust the lens, the camera body vibrates, preventing it from properly focusing or taking pictures.
if you have any problem regarding this issue post a comment information about the problem.we will glad to assist you
good luck
Aug 26, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
BENQ G2200W LCD Monitor has a vertical line
Try it on another computer, if the problem is apparent on 2 different computers the monitor is defective.
Jul 15, 2017 | BenQ 22" G2200w LCD Monitor
Lost signal from the satellite
Signal Fade And Loss ~ Important, especially during winter!
Keep in mind that satellite broadcasts occur directly from fixed satellites in space to users. UPLINKS TO that satellite can happen from almost anywhere in the world! This includes broadcasts from remote studios, satellite vans and trucks.
Even signals from the main providing studios are susceptible to weather conditons even tho they have huge, high-gain transmitting dishes!
Weather is a major factor for both the uplinks and downlinks! Storm clouds can block the signals anywhere in the signal path(s). Rain clouds do too ~ even if it's not raining yet. Water-laden clouds make some of the BEST signal attenuators.
So one may have a gorgeous day in San Diego (let's say), but storms back east could trash satellite reception at his location and potentially everywhere else!
As you know, weather conditions all over the US are changing constantly with many severe storms occurring this past week and during any winter. In fact this week there was total signal loss on several satellites and I suspect storms back east were a big factor.
So it could have just been issues of timing for you. The UPLINK had intermittent problems with signal paths semi-crippled by weather... YOUR weather was CLEAR, but your reception was far from problem free ~ only because of weather problems elsewhere.
If you see intermittent satellite reception do check out the weather... especially back east.
Hope this helps!
Feb 01, 2009 | DISH Network Televison & Video
Ixus 750 Blurred photos shot at a distance greater than a meter.
Check to see that the camera is not in "macro" mode, which would only allow focusing at a close range, but not allow focusing at beyond about 2 meters (look for the "flower" symbol to tell you that macro is activated). Could also be an out of adjustment lens, due to impact or force. Also check to make sure it's not as simple as a dirty lens. Digital cameras are more succeptable to blurry pictures from a smudged lens than film cameras were. Of course, that wouldn't explain why close shots are OK but distant ones aren't. Probably the first two suggestions.
Oct 06, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Video Flip-flops when shooting outdoor/Focused Bright Area OR Light
Hi Ramki
Camcorder can not be drop, maybe the brain damage and give the wrong figures to the camcorder and caused shot off and on.
I feel sorry about this bad situation, maybe if you have menu, see the trouble shoot, but I doubt it.
May 21, 2008 | JVC GR-D22U Camcorder
Canon PowerShot S51S Digital Camera Logo
111 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
