Question about Frigidaire Washing Machines
My frigidaire smartdrive 603 has no issues with filling and emptying however it frequently pauses mid cycle and beeps with hot/ cold lights flashing?
  • 157 Answers
SOURCE: Fisher & Paykel Smartdrive 7kg is filling very
Make sure that your incoming cold water valve is open fully. If it is, then you will have to clean the valve inside the machine for the cold water inlet.
Posted on Nov 03, 2009
  • 3 Answers
SOURCE: Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Posted on Feb 20, 2010
  • 1531 Answers
SOURCE: fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Posted on Mar 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a smartdrive 601 that will not fill start
hot and cold hoses connected backwards
Posted on Mar 22, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
good luck
Jul 06, 2010 | Washing Machines
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Slow Filling only in rinse cycle
Tony, the fact that you are not receiving any error codes tends to leave me to believe that your cold fill hose filter may be restricted. Going by your model number you can enter this mode by having the power on at the source and off at the console. Press and hold the lifecyle button and then push power button. You should hear 2 beeps and then the display go blank. You can test the hot and cold valves by pressing how dirty up (hot) and how dirty down (cold). If you find the cold valve slow as in your rinse check for restrictions. If it were the thermistor, I would think you would receive an error code..Good luck.
Jun 06, 2006 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
