Question about Compaq Presario 700 470024-192 Notebook
My sound devices is properly working but when i try to speak in mic then nobody can here me but i able to here them.
  • 396 Answers
If you have WIN 7 you have to go to CONTROL PANEL and choose SOUNDS. The tab that opens
has Playback and the next tab is RECORDING. Click on it. Make sure there is a checkmark on MICROPHONE. If you dont see MICROPHONE do a right click and make sure SHOW DISABLED DEVICES and SHOW CONNECTED DEVICES is checked. Anything you missed will be there from now on. Hope this helps.
Vista and XP are about the same and sometimes you can just right click on the speaker on the bar where the clock is and choose MIXER SETINGS or RECORDING DEVICES to get to the same area for adjustment.
Posted on May 29, 2011
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
Dec 09, 2013 | Logitech G930 Wireless Headset
Im trying to use skype but nobody can hear me and i dont know what i need to do
Make a call to echo
Echo will ask for you to speak and then your words will be echoed back. If you don't hear your voice you need to make sure Skype is using the right microphone input. If you are using a desktop PC with a USB camera, you may want to make sure you have the input settings set to the camera as they default to the on-board sound card.
Likewise, if you have some sort of device that could have diverted the mic input away from the microphone you need to check that too.
So from Skype:
  • Go to Tools menu
  • Choose Options
  • Choose Audio Settings
  • Make sure the Microphone is on the right device
Jul 22, 2011 | Computers & Internet
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
People cannot hear me
If your webcam has a built in mic make it the default mic
XP
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Vista
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Configure your webcam to the chat program
Aug 22, 2010 | Logitech Webcam
The test says its work but nobody can hear me.
If you have a mic built in to your webcam you have to make it your default mic. Especially if you also have a laptop with a built in mic.
If your OS is pre-Vista you will have to set your webcam mic as default from the Control Panel - make sure it's plugged in
Vista
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 19, 2010 | Logitech QuickCam Express Web Camera
5300 mouthpiece is not working
this problem from mic which located in the face cover if you can remove the face cover and check the mic and feeb back
Apr 15, 2010 | Nokia 5300 Grey Cellular Phone
When trying to speak to contacts on skype a message saying 'internal microphone not working' keeps appearing. Any suggestions of what to do?
Check your mic if properly plugged. Check hardware devices if mic is properly installed by right clicking my computer then properties. On properties window, go to harware tab and choose device manager. Check mic if installed. If not install it, if installed check properties if there is a problem. If there is reinstall it if not check volume properties if mic volume is not muted.
Dec 01, 2009 | Computers & Internet
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Compaq Presario 700 470024-192 Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
